The Nullabor
Discussion in 'Australian Motorcycles' started by Will S, Jun 22, 2005.
  1. Will S
    G-S Guest
    Isn't that just around the S bend from Disney world?
    G-S
    G-S, Jun 30, 2005
  2. Will S
    G-S Guest
    That goes some way to explaining things... I tend to ride naked bikes,
    or bikes
    with small half fairings at best...
    G-S
    G-S, Jun 30, 2005
  3. Will S
    G-S Guest
    If it was hiding in Johno's letterbox that would explain why he was
    afraid to ride past it!
    G-S
    G-S, Jun 30, 2005
  4. Will S
    G-S Guest
    True... but then I tend to wear long thermals in winter and thermal
    singlets as well :)
    G-S
    G-S, Jun 30, 2005
  5. Will S
    Will S Guest
    Actually the signposted turnoff to Buchan is on the left, not the right
    (though there is an unsignposted turnoff on the right about 2km further
    along. Take the left turn real easy especially if the road is wet, it's a
    270° left hander which immediately passes back under the Princes Hwy. There
    are a few turns to make in the first few km and they're not always in the
    logical direction so at each intersection slow down and read the signposts
    and
    follow the Buchan signs.
    thx for that tip
    If your plan is to follow the freeway into Melbourne and out the other side
    to
    Geelong You might find it more entertaining to avoid Melbourne all together,
    head south to Sorrento and catch the ferry across to Queenscliff instead and
    head to the GOR via Barwon Heads.
    How often does the ferry cross ?
    The ride through Melb is piss poor and the ferry detour sounds a good idea
    thx Nev
    Will
    Will S, Jun 30, 2005
  6. Will S
    Will S Guest
    How long did it tale you ?
  7. Will S
    Will S Guest
    A man after my own taste of depravity
  8. Probably better than Disney world...
    Hammo (dys )
    Hamish Alker-Jones, Jun 30, 2005
  9. Will S
    Will S Guest
    Dont worry about it Nev as I got of my arse or to be more exact sat down on
    my arse
    and googled.
    Its a definite part of my trip.....
  10. When I picked mine up, with 5600 km on it, it still had the original
    rubber on it. 2000 km later, the rear was well and truly shagged (on the
    sides, not so much the centre) and the front was looking a bit tired.
    Just replaced both with Shinko tyres for $229 all up. They're the same
    construction (same factory actually) as the continentals. Stickier than
    the BT012SS, but probably won't last quite as long - but at half price
    it is hopefully worth it.
    Question: how come you're getting rid of your FJR?
    Cheers
    PeterC [aka MildThing]
    '81 Suzuki GS450-s (gone on to better and brighter things - I hope)
    '87 BMW K100RT (write-off)
    '81 Yamaha Virago (XV) 750H (work in progress)
    '01 Yamaha FJR1300
    www.dmcsc.org.au
    http://eladesom.com.au/ulysses/
    # 37181
    Peter Cremasco, Jun 30, 2005
  11. Will S
    smack Guest
    sorry, meant hamburger, not mince. Something about fillet steak
    And no I didn't ride this week, had a shitty headcold. Promise I'll call
    when I get better
    smack, Jun 30, 2005
  12. Will S
    G-S Guest
    Ooooo.... you really shouldn't dys clem...
    G-S
    G-S, Jun 30, 2005
  13. Will S
    David Guest
    ....snip
    Pardon me for being a pedant, but I'm having trouble imagining a 270°
    left hander. Isn't that going to be the same as a 90° right hander ?
    David :p
    David, Jun 30, 2005
  14. Will S
    Moike Guest
    Yep. The road loops back under the highway.
    The entrance from Sth Gippy Hwy to the Monash is more like a 300° left
    hander.
    Moike
    Moike, Jul 1, 2005
  15. Will S
    IK Guest
    FFS...
    IK, Jul 1, 2005
  16. Will S
    Theo Bekkers Guest
    It's an anti-clockwise roundabout.
    Theo
    Theo Bekkers, Jul 1, 2005
  17. Will S
    Theo Bekkers Guest
    There's a story to that.
    Theo
  18. Will S
    Nev.. Guest
    The nett result is much the same but you don't wear out the right hand side of
    your tyre.
    Nev..
    '03 ZX12R
    Nev.., Jul 1, 2005
  19. Will S
    sharkey Guest
    Nope. If you took a 90° right hander there, you'd pin the armco
    and then fall several meters onto the road below.
    Better to follow road around to the left and under the highway, I
    think ...
    -----sharks
    sharkey, Jul 1, 2005
  20. The Cahill Expressway weat/northbound onto the harbour bridge in
    Sydney...
    There's usually some elevation change involved...
    big
    Iain Chalmers, Jul 1, 2005
