the moral compass
Discussion in 'UK Motorcycles' started by darsy, Oct 20, 2003.
  1. darsy
    Ginge Guest
    I wouldn't really know about back of a fagpacket solutions, most of the
    systems I work with are quite large.
    Ginge, Oct 24, 2003
  2. darsy
    what a load of crap. Unless by "specialised" you mean "commercial".
    darsy, Oct 24, 2003
  3. darsy
    PeterT Guest
    Dr Ivan D. Reid
    Was there 'intelligent' life before the clique?
    PeterT, Oct 24, 2003
  4. darsy
    What a load of shite. You obviously don't work in the commercial IT
    arena.
    Champ, Oct 24, 2003
  5. darsy
    M J Carley Guest
    Red Hat is the nearest thing in the Linux world to MS and I hate it,
    as do others
    http://www.rumble.net/redhatsucks.html
    I was obliged to install it recently because it was the only readily
    available set of disks which had drivers for the SCSI in the new box
    and I found it had an `upgraded' kernel with alpha-test features which
    meant that the data acquisition library couldn't be installed which
    meant I had to find a vanilla kernel and install that instead.
    Slackware's very good on the other hand.
    M J Carley, Oct 24, 2003
  6. darsy
    M J Carley Guest
    So don't use them. You have a choice of window managers under Linux,
    unlike MS.
    Not something a punter is liable to do.
  7. darsy
    Simian Guest
    Des Coughlan :
    "unix is the way forward because a user can't do any damage" is only
    true of systems run by a competent sys-admin. Unless M Carley is
    suggesting that we take away everyones home PC and replace it with a
    dumb terminal, his was statement did not have the value 'true'.
    There are a variety of ways in which a user can temporarily (fork
    bomb) or permanently (installing stuff as root) screw up a *nix OS.
    Simian, Oct 24, 2003
  8. darsy
    M J Carley Guest
    But you generally have to work at cocking up a Unix box. You can't,
    for example, delete system files by accident. And they don't get
    viruses.
  9. darsy
    Catman Guest
    I think you'll find there are actually other window managers under MS.
    There are certainly different UIs. They are not as easy to swap
    between though IME
    Alfa 116 Giulietta 3.0l. Really, Sprint 1.7
    Ducati Monster 600 Metallic
    www.cuore-sportivo.co.uk
    Catman, Oct 24, 2003
  10. darsy
    heh. Rubbish.
    darsy, Oct 24, 2003
  11. darsy
    M J Carley Guest
    How many Linux/Unix viruses are there? A hundred?
  12. darsy
    Only if you're a numpty, and find things like doing up your shoe laces hard.
    Muck
    Bandit 600n(With added ducktape); CG125(MSOHPR)
    "I've got a CG125, and I'm not affraid to use it."
    DS#1 ; DOMO#1 ; SH#2 ; ICQ: 166144431
    Remove _TEETH_ to e-mail
    Muck, Oct 24, 2003
  13. darsy
    even if it were only a hundrew, your statement "they [unix] don't get
    viruses" is clearly false.
    darsy, Oct 24, 2003
  14. darsy
    PeterT Guest
    Muck
    hard.
    Dunno, it's a pretty tough job, them laces, I always go with velcro.
  15. darsy
    M J Carley Guest
    Pedant.
  16. darsy
    Oi! What about wellies or flip flops?
    Muck
    Muck, Oct 24, 2003
  17. darsy
    PeterT Guest
    Muck
    I got confused with flip flops, didn't know which side the toes go.
    And I'm not allowed wellies since the incident.
  18. darsy
    Hmmm, tricky. Paint your feet black and wear no shoes?
    Muck
    Muck, Oct 24, 2003
  19. darsy
    PeterT Guest
    Muck
    Aye. and I got a white marker pen so I can draw some laces on them.
    Looks pretty real. ;-)
  20. darsy
    Simian Guest
    M J Carley :
    I don't think I've managed to delete a windows system file by accident.
    Anyway, so *nix is the way forward right up until Bill adds the 'protect
    system from numpty' option to windows is it?
