The laying of floors
Discussion in 'UK Motorcycles' started by 'Hog, Mar 19, 2010.
  1. 'Hog
    You were pretending to be Australian?
    ogden, Mar 19, 2010
    #41
  2. 'Hog
    ginge Guest
    I fitted a 19 x12 living room and 15x12 dining room full of the stuff
    in 6 hours one night, the only trick is having a decent jigsaw to cut
    the ends, and (in my case) leaving an extra bit on and using a set of
    files to shape a few pieces to dip into doorframes with an inset
    decorative edge.
    Piece of piss to do, really it is.
    ginge, Mar 19, 2010
    #42
  3. 'Hog
    'Hog Guest
    It detailed where I am and asked whether that was a distance he would
    travel. so yes.
    'Hog, Mar 19, 2010
    #43
  4. 'Hog
    SteveH Guest
    We just had bamboo laid in the hall and dining room - the local guy
    recommended by the supplier charged £15/m2.
    Having seen how hard it was to get it all laid up properly and cut
    around the dodgy angles etc [1], I was more than happy to pay that.
    [1] He used some kind of ratchet strap arrangement to get all the boards
    nice and tight.
    SteveH, Mar 19, 2010
    #44
  5. I might be able to help
    steve robinson, Mar 19, 2010
    #45
  6. Thats quite possible if both rooms are square , if you start to allow
    for bays and fire places then the fitting times rise
    #46
  7. 'Hog
    ginge Guest
    3 bays, 1 fireplace, some alcoves, a bit of 45 degree wall, and a
    partitiony bit. 6 hours, and I might have stopped for a cuppa at some
    point.
    ginge, Mar 19, 2010
    #47
  8. This i would like to see :)
    #48
  9. 'Hog
    ginge Guest
    The real trick I found to it is to lay each plank up to where it meets
    interference from a wall or whatever, scribe it in situ using a
    permanent CD pen or similar, then pop it out, and trim the bulk out
    with a jigsaw, using a rough-ish file to take the last bits out and
    drop it back in. Probably takes a few minutes a time using that
    approach.
    ginge, Mar 19, 2010
    #49
  10. 'Hog
    Jérémy Guest
    Me too.
    This could be the thread of the year.
    Jérémy, Mar 19, 2010
    #50
  11. I prefer to use the laser and the bench saw , far quicker and less
    brutal , i dont scribe around the architraves i trim them off ,
    neater finish and covers any expansion . Door frames i use an edge
    trim cover prefixed or trim the frame depending on wether its going
    to be a continous run or stopped fixing .
    Any scribing is done with a small router and guide pin bar , fast ,
    clean edge and very accurate .
    #51
  12. Even the floor of the year.
    #52
  13. 'Hog
    turby Guest
    You need to get laid more.
    turby, Mar 19, 2010
    #53
  14. Caused by numpties turning it up too soon.
    Grimly Curmudgeon, Mar 20, 2010
    #54
  15. Don't forget vets. Many vets are damn good at it.
    #55
  16. DeWalt, and New Yankee Workshop?
    #56
  17. 'Hog
    Puts me in mind of the time Sarah called me a "classic passive-aggressive".
    platypus, Mar 20, 2010
    #57
  18. 'Hog
    pish and tosh.
    There's nothing "classic" about you.
    darsy, Mar 20, 2010
    #58
  19. 'Hog
    Drop me a line to the unmunged email please?
    Being something of an Aberdonian paying retail for anything is an issue
    Hog, Mar 20, 2010
    #59
  20. 'Hog
    Quite. I've always considered myself somewhat nouvelle vague.
    #60
