The Disappearing Oil Trick
Discussion in 'UK Motorcycles' started by John Heath, Apr 17, 2004.
  1. John Heath
    John Heath Guest
    Just had two weeks in Spain on the Pan - brilliant roads, friendly people,
    lunatic car drivers, cheap everything.
    On the way back, the Pan started vibrating through the footrests - at odd
    times which I couldn't pin down to any one set of circumstances. It would
    do it for a second or two, then all was OK again.
    We stopped over and I checked the oil first thing in the morning. Nothing
    in the glass viewer. Yes - that'd probably do it, but I was confused. Two
    days previously, the level had been OK. I wasn't on a slope, I ran the
    engine and let the oil settle again. Still no oil in the viewer. Took the
    bike 100 yards to a garage, put it back on the centre stand, bought some
    oil. Gave time to let oil settle down and filled it up to just under max.
    It took about 3/4 litre.
    I didn't get the vibration during the 3 hour run home.
    Got home. Worried about where all this oil was going, I went to check the
    level again. Full. Way above max. I had to let out (I guess) about half a
    litre.
    So where the hell did all that oil go to before ?
    Any ideas ???? (and no - it wasn't on a slope, on a side stand or owt like
    that).
    John Heath
  2. John Heath
    Porl Guest
    And then come back again? Gee, I'm going to stick my neck out here and
    suggest maybe you didn't warm the oil up enough, as incredulous as it
    sounds. Either that ot it was hiding from you for a joke.
    Porl, Apr 17, 2004
  3. John Heath
    YTC#1 Guest
    Or, due to the heat, it had evaporated.
    YTC#1, Apr 17, 2004
  4. John Heath
    Can oil re-condense?
    sweller, Apr 17, 2004
  5. John Heath
    YTC#1 Guest
    Cambells would make a fortune.
    YTC#1, Apr 17, 2004
  6. John Heath
    OH- Guest
    Without starting the engine at all ? If so, I'm as confused as you as to
    where it was hiding.
    This is more typical. The still comparatively cold oil gets pumped out
    but takes a long time to drain back
    Are you sure the bike isn't a diguised XT600, the whole thing seems very
    familiar.
    This story is another example of why one should always check oil level
    after a ride, not before. It gives much more consistent results.
    OH-, Apr 17, 2004
  7. John Heath
    Oldbloke Guest
    Easy.
    Some sadistic bastard has swapped your Honda engine for a 2 litre VW Golf
    GTI Petrol unit.
    "They all do that sir" - yes, especially mine.
    Dan L (Oldbloke)
    My Bike 2000 Honda CB500
    M'boy's Bike 1990 Suzuki TS50X (Heavily fortified)
    BOTAFOT #140, DIAABTCOD #26
    Oldbloke, Apr 17, 2004
  8. John Heath formulated on Saturday :
    It might just possibly be that water has got into the sump and is
    evaporating during the course of a run.
    Harry Bloomfield, Apr 17, 2004
  9. Centre stand, ran the engine and let it settle again, and got home, then
    went to check the oil again, are the key words here. Me thinks that the
    oil didn't have enough time to drain back into the sump. Probably from
    the oil filter and camshaft galleries.
    Check it when cold in the morning. Off the centre stand I believe...
    SimonB - South Wales. BOF#32
    email
    http://simonb.zapik.co.uk
    Triumph Sprint ST, ZXR750L2 Wazimbaki. Kawasaki Z1R *Still For Sale*
    CON of the month http://zapik.com/simonb/fiddle.html
    eric the brave, Apr 17, 2004
  10. Listen, mate, if you had a BMW 'boxer' twin, you'd be used to this sort of
    thing - seriously! I don't mean the vibration so much - what can you say
    about the vibration of a horizontally-opposed twin - but the 'hiding' oil
    phenomenon is perfectly normal. Didn't know it applied to Pans though - will
    ask my chum Ed tomorrow, 'cos he's got one.
    Rick
    Richard Sterry, Apr 17, 2004
  11. John Heath
    Cerberus Guest
    maybe Campbells would as well ? ;-) www.campbellsoup.co.uk
    Cerberus, Apr 18, 2004
  12. John Heath
    Christofire Guest
    It might be different for yours, but Suzuki recommended running the
    engine for about 2 mins to heat up the oil, then switching it off and
    checking the level after 30 seconds. You might want to find out what
    the exact method is to make sure you're checking the level correctly.
    Christofire, Apr 18, 2004
  13. John Heath
    Zymurgy Guest
    Jesus, yes, you too ?
    My SO's [1] GTI does the same. Hers has done 20K and uses 3 times as
    much oil as my 100K Mazda.
    Guess who gets the job monitoring, buying & filling it ....
    Cheers,
    Paul.
    [1] Well, "ex" if we're being pedantic ...
    Zymurgy, Apr 18, 2004
  14. John Heath
    Oldbloke Guest
    Zymurgy wrote:
    Ho Yuss, 1 litre every 600 miles, which according to the manual, and the
    dealer is "acceptable", from a 1999 model with 64K miles, although it's used
    the same amount when I first bought it with 24K miles on the clock.
    <snip>
    Dan L (Oldbloke)
    Oldbloke, Apr 18, 2004
