The advisability of riding with a dodgy exhaust?
Discussion in 'UK Motorcycles' started by Lady Nina, Jul 18, 2004.
  1. Lady Nina
    Lady Nina Guest
    Warning - my engine systems knowledge is limited.
    It goes something likethis - you mix the petrol and air, set fire to
    it, it explodes, which pushes something [1] which pushes something
    else and the wheels go round. All the left over bits from the
    explosion go through these things called exhaust pipes.
    Now apparently the bits of the exhaust called down pipes on the ZXR
    are broken and I need new ones. And I have been told if I ride very
    far with these broken I can break other bits of the engine in a
    variety of possible ways ranging from 'oh dear' to 'oh ****'.
    Now the thing is, I'm in Newbury next weekend and was thinking about
    nipping into Platy's on the way back. And I don't want to arrive at
    Platy's in a car.
    So if I do a couple of hundred miles in a sensible manner will I be
    able to cross my fingers and hope and get away without any major
    damage or is it like russian roulette?
    Can I not bandage the poorly exhaust until I (well someone else really
    as I haven't even started looking) finds replacement downpipes?
    [1] is this bit the crank shaft? If I have one of these does it mean
    the bike will not wheelie?
  2. Lady Nina
    Nick Pring Guest
    I have ridden and mates have ridden, grammer?
    bikes with bandaged exhausts for miles
    please note, ( the get out bit if it all goes tits up)
    this is just IMHO and experience
    good luck
    nick
    Nick Pring, Jul 18, 2004
  3. Lady Nina
    mups Guest
    Lady Nina says...
    suck, squeeze, bang, blow
    Depends on how badly holed they are and how hard you ride it. With a
    hole in the exhaust your mixture will be weaker as in to much air and
    not enough fuel and you could run the risk of holing a piston(s)
    Take the CG[1]
    It should be OK if you take it easy but plod might not be impressed with
    the noise.
    Exhaust bandage works but its not a permanent fix.
    the bit which gets pushed is the piston. The crank shaft is pretty much
    essential for wheelies.
    [1] or GC as you call it
    mups, Jul 18, 2004
  4. Lady Nina
    Ben Blaney Guest
    Why not?
    Ben Blaney, Jul 19, 2004
  5. Lady Nina
    deadmail Guest
    'cos it's a ukrM meet. Innit.
    Can't go to a bike NG thing in a car! Just doesn't fit.
    deadmail, Jul 19, 2004
  6. Lady Nina
    Ben Blaney Guest
    Good point, well made.
  7. Lady Nina
    entwisi Guest
    Now I've always wondered about this, since there is no 'link' between the
    exhaust and the inlet manifold/carb/injectors how can a hole in the
    exhaust make the carb/injectors suddenly change the mixture(all excepting
    some of the more modern stuff with lambda sensors/cats). After all the
    carb gets asked for Xcc of air mixed with Y% fuel nicely mixed in it
    please?
    I used to hold the exahust of my rev n go on with exhaust putty when I was
    16 and couldn't afford to get it fixed properly. I think I kept Mr Holt in
    business that year.
    entwisi, Jul 19, 2004
  8. Cuntybollox wrote
    I am confused. How does being compared unfavourably to Bear happen
    then? And is it a bad thing?
    I have seen him on a bike. Blue it was.
    steve auvache, Jul 19, 2004
  9. Lady Nina
    Mark Olson Guest
    Actually there *is* a link between what happens in the exhaust system
    and the fuel mixture being rich/lean. Why do carbs need to be rejetted
    when fitting a less restrictive exhaust? A little googling may help
    you to understand why.
    Mark Olson, Jul 19, 2004
  10. Lady Nina
    Lady Nina Guest
    I'd like to get there in less than 5 hours.
    It sounds lovely.
    Thinking about this. use of car or bike depends on if we're well
    enough to ride by then as well.
    Did I? There was alcohol involved wasn't there...
    Lady Nina, Jul 19, 2004
  11. Lady Nina
    Lady Nina Guest
    Because you lot would take the piss at any opportunity perhaps?
  12. Lady Nina
    SOP, innit. Duck's back, water.
    Use the car, park round the corner and stroll in wearing a bike jacket
    and carrying your lid - it's what most people do ;-)
    We'll be in the car anyway, due to having a large item to collect on
    the way home.
    Pip, Jul 19, 2004
  13. Cuntybollox wrote
    As I have reached almost Des like levels in desperate longing for
    something to actually happen to me I am not sure. Which is why I arsed
    the question.
    Only if he was riding it faster than Ginge.
  14. Lady Nina
    Pip says...
    If you're going to continute taking the piss out of the way I've put
    weight on, I'll take my bike.
    Lozzo, Jul 20, 2004
  15. Lady Nina
    He had a green one when I saw him.
    sweller, Jul 20, 2004
