that's me officially out of date with PC hardware
Discussion in 'UK Motorcycles' started by darsy, Jan 3, 2008.
  1. darsy
    guess what idiot bought a graphics card not realising that "PCIe"
    cards don't fit in PCI slots?
    darsy, Jan 3, 2008
  2. darsy
    Steve Parry Guest
    In
    do they not fit ISA slots then? :)
    Steve Parry
    K1200GT SE & F650
    '87 Yamaha FS1 & Sukida SK90PY
    and a VW Passat SE Estate for comfort
    www.gwynfryn.co.uk
    Steve Parry, Jan 3, 2008
  3. darsy
    Cab Guest
    Angle grinder.
    Cab, Jan 3, 2008
  4. darsy
    MikeH Guest
    They will go in, but with a bit more of a "click" than usual.
    MikeH, Jan 3, 2008
  5. darsy
    Cane Guest
    but at least you can challenge and translate business requirements
    into competitive solutions
    Cane, Jan 3, 2008
  6. darsy
    there's always that.
    darsy, Jan 3, 2008
  7. darsy
    Ofnuts Guest
    Ah, so that's what "AG" mleans in "AGP"?
    Ofnuts, Jan 3, 2008
  8. darsy
    Geo Guest
    The real question is, why would you want to get a PCI gfx card in 2008?
    Btw, a PCIe card should be worth more than a computer than needs PCI
    graphics....
    Geo
    Geo, Jan 3, 2008
  9. darsy
    so A. can play the latest Broken Sword game that requires DirectX 9.0c
    on her 3-year-old PC.
    The card was 17 quid - I think the PC's probably worth a little more
    than that.
    darsy, Jan 3, 2008
  10. darsy
    Geo Guest
    Fair enough, I thought non-AGP motherboards died earlier than that. 3 years
    old isn't half what I expected your comp to be. I also expected gfx cards to
    be a bit more expensive...
    Geo
    Geo, Jan 3, 2008
  11. darsy
    actually, it was only 2 years ago I bought it - it's one of these:
    http://uk.insight.com/apps/productpresentation/index.php?product_id=FJSCA04M4U
    I suppose I'll have to see if there exists such a thing as a PCI
    graphics card that does DirectX9.0c
    darsy, Jan 3, 2008
  12. darsy
    Geo Guest
    I should have guessed it had integrated graphics and therefore no AGP slot.
    Costs less but makes upgrading a PITA. Are you sure you can disable the
    onboard gfx chip and use the PCI card as a primary output?
    The nVidia FX 5200 seems to be 9.0c capable, you might want to have a look
    yourself.
    (For sale: 128MB http://www.ebuyer.com/product/119725 , there's a 256MB
    going on eBay, item 200188636629) but at 30-odd quid new I wonder if it'd
    make better sense to look for a cheap motherboard with an AGP slot and a
    card for it. Might cost a bit more as a whole (and cause a slight fuss with
    Windows having to adapt and find all the drivers) but it should be a better
    solution for gaming. Provided your PSU manages...
    Geo
    Geo, Jan 3, 2008
  13. darsy
    Yes - I've already checked the BIOS.
    I did check the nVidia FX 5200, and yes it claims to be DirectX 9
    compliant, but not /necessarily/ 9.0c (which the game specifically
    requires, some cell shading gubbins)
    a) more hassle than I can be bothered with and b) she's not exactly a
    "power gamer", she's only trying to play the latest Broken Sword, FFS.
    darsy, Jan 4, 2008
  14. darsy
    Geo Guest
    Not sure, although some people in forums seemed to be running it with 9.0c.
    Then again said people were usually asking "what's wrong with...." and I
    didn't check whether it was some gfx issue.
    I wouldn't know, my Athlon@500MHz-GeForce2 GTS desktop won't handle anything
    over Age of Mythology.
    Geo
    Geo, Jan 4, 2008
  15. darsy
    Geo Guest
    Not all integrated-gfx MoBos lack and AGP slot but all (at least most) MoBos
    lacking an AGP slot should have integrated graphics. Before PCIe anyhow.
    Geo
    Geo, Jan 4, 2008
  16. darsy
    Cab Guest
    My Radeo X1950 Pro is the dogs nads. Especially with COD 4, which I'm
    going to play all over again, as I was too impressed.
    Cab, Jan 4, 2008
  17. darsy
    Molly Guest
    I got out of date within three months after I left the industry.
    Molly, Jan 4, 2008
  18. darsy
    Cab Guest
    Where you're waiting for the chopper? Well, instead of waiting next to
    your injured boss, turn to the right of him and run all the way down to
    the end. Hide behind the rides, as there is only one way that you can
    be attacked.
    You can defend the area quite easily with claymores and also shoot the
    buggers over the top of the ride (which is on a sort of platform)
    IYSWIM.
    Cab, Jan 4, 2008
  19. darsy
    Cab Guest
    On the hardware side, I know I've slipped slightly. On the OS side,
    loads. I don't know how Vista works or 2007 Server. You're right, you
    lose touch quickly.
    Cab, Jan 4, 2008
  20. darsy
    ginge Guest
    There isn't a 2007 server... So you're more up to date than Microsoft!
    ginge, Jan 4, 2008
