That was a little nerve-racking
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Dec 28, 2007.
  1. Wicked Uncle Nigel
    AW Guest
    Heh. Sure the Commando engine had been around for at least 30 years
    in one size or another, but the 750 Commando was a "new bike" (OK
    warmed over Atlas) in 1967. 'Owever, the WUN Notrun dates from 73 and
    the Morini dates from 76 so they are almost contemporaries, by way of
    build date, if not ethos.
    The Morini looks like what it is - a handbuilt bike derived from the
    racing expertise of the Morini factory while the Notrun is an
    antediluvean bodge up.
    </Brum accent> - "By Eck, our bike's getting a bit outdated. Better
    bore it out a bit and strap some more pig iron to the frame so it
    don't leap through the tank".
    When I was rewiring it, I couldn't find the connector block that joins
    the main loom to the headlight loom in the kit of parts from Norvil.
    It was a sort of rubber thing with about 10 connectors in it. Rang
    Norvil and got put onto Reg (or something), their leccy man, a
    veteran of the Norton Factory -
    AW: I havn't got this big connector block in the parts you sent me
    Reg: No, you wouldn't have. That alwasy used to wear a bit and then
    short out. Having a fire under the petrol tanks not a great idea so
    we don't supply them, Just get a load of single connectors and use
    them.
    Bad electrics, so even more similar to the Morini!
    AW, Dec 29, 2007
  2. Bloody 'ell.
    The Older Gentleman, Dec 29, 2007
  3. Wicked Uncle Nigel
    AW Guest
    Indeed. Production engineering wasn't something apparently given high
    priority at the Nortin factory. Ask me about the horn.....
    That said, a sunny day on a big, torquey Norton with the exhausts
    making that *fantastic* noise is a sensory feast.
    AW, Dec 29, 2007
  4. Um, should I?
  5. Wicked Uncle Nigel
    AW Guest
    Only if you want to make me go
    "aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaargh"
    AW, Dec 29, 2007
  6. Wicked Uncle Nigel
    zymurgy Guest
    zymurgy, Dec 29, 2007
  7. Wicked Uncle Nigel
    They're now French. IIRC.
    sweller, Dec 30, 2007
  8. Wicked Uncle Nigel
    Where does the Guzzi 850-Tx series fit in this...
  9. Wicked Uncle Nigel
    JB Guest
    Not the ones I've got matey :>)
    I tend to keep my tools *forever*. I've still got the handtools my
    grandfather left me from his apprenticeship at Sturmey Archer.
    I still have to work out what one or two of them actually _do_!
    JB
    JB, Dec 30, 2007
  10. Wicked Uncle Nigel
    JB Guest
    In pride of place.
    Now ask me about the Yam TX750 and how that could ever have happened if
    accountants had really ruled the factory .
    JB
    JB, Dec 30, 2007
  11. Wicked Uncle Nigel
    Neither are the ones I have but if anyone's considering "buying British"
    they might want to know.
    I have many tools like that.
    sweller, Dec 31, 2007
  12. A sensible use of an existing design that was intended for something
    else.
    GS850x2 XS650 SE6a
    "A scone and tea at half past three
    Makes the day a little brighter
    Keep your cakes and fancy tarts
    And stick them up your shiter."
    Grimly Curmudgeon, Dec 31, 2007
  13. Using the patented Mavis Beacon "Hunt&Peck" Technique, AW
    Heh. It is an established fact that at the very beginning of the
    Commando production line, there was a horn. They then started bolting
    bits to it until they had a completed motorcycle.
    Disassembly is the reverse of assembly...
    Honda GL1000K2 (Fallen apart) Suzuki TS250 "The Africa Single"
    Norton 850 Commando Kawasaki GTR1400
    Wicked Uncle Nigel, Dec 31, 2007
  14. Using the patented Mavis Beacon "Hunt&Peck" Technique, AW
    It's been a challenge. The DVD claims that all bushes are supplied to
    final size. That's *mostly* true.
    However, the first gear bush was a good 10 thou undersize on the ID.
    Luckily a little rummaging scared up a decent 11/64" reamer that dealt
    with the problem very nicely.
    Now, if someone could just tell me where I put the fucking sprocket nut,
    I could get the primary back on and get it all buttoned up.
    Ask nicely and I might let you have a go.
  15. Wicked Uncle Nigel
    AW Guest
    Wicked Uncle Nigel
    wrote:
    Mick Hemmings says when rebuilding a Commando, to be *very* sure the
    horn is working before moving on with the rebuild.
    AW, Dec 31, 2007
  16. Wicked Uncle Nigel
    AW Guest
    Nooooooooooooooooooooooooo.
    AW, Dec 31, 2007
  17. This sounds a bit like BMW's habit of building a motorcycle around its
    clutch. Why not just move the horn to somewhere more accessible???
    The Older Gentleman, Dec 31, 2007
  18. Wicked Uncle Nigel
    AW Guest
    When I sold the Notrun to WUN, I had a Fiamm mounted (temporarily) on
    the headlight brackets as it wouldn't fit into the area around the
    battery. I'd imagine WUB will be moving it to somewhere less
    obtrusive.
    AW, Dec 31, 2007
  19. Wicked Uncle Nigel
    They only do that after they've welded the rear subframe together around the
    battery.
    platypus, Dec 31, 2007
  20. Wicked Uncle Nigel
    SD Guest
    Like GL12's being built around the alternator, or the Fifteen being
    built around the hydraulic lines?
    | ___ Salad Dodger
    |_\_____/_| ..93550../..25068.../..31928.
    SD, Dec 31, 2007
