That was a little nerve-racking
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Dec 28, 2007.
  1. Notrun Owners' Club gearbox DVD:
    "Yow kin just run a tap into this bush and then pull it out, or yow kin
    bore it out onna lathe".
    No suitable size tap to hand, so boring it out it was.
    Straightforward enough, but an up-**** would have been a tad spendy. I
    just hope I can press the new one in nice and straight.
    Honda GL1000K2 (Fallen apart) Suzuki TS250 "The Africa Single"
    Norton 850 Commando Kawasaki GTR1400
  2. Wicked Uncle Nigel
    DDastardly Guest
    Swinging arm bushes?
    DD
    DDastardly, Dec 28, 2007
  3. Wicked Uncle Nigel
    JB Guest
    If you ever need big taps let me know. I've got metric coarse & fine to M32)
    Not the time for a clamp or bolt to move on a faceplate, or the fucking
    phone to ring, or a mate to tell you _right in your ear_ that "you really
    don't wanna do it like that"
    As for pressing the new bush in straight, what about using a mandrel in the
    bush mounted in the tailstock to get it started then remove as an assembly
    to your new press for final pressing in? I'd do the final reaming in the
    lathe though whatever method you use to get the bush in.
    Good luck.
    JB
    JB, Dec 28, 2007
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, DDastardly
    Gearbox.
  5. Using the patented Mavis Beacon "Hunt&Peck" Technique, JB
    Noted, ta. I've got a few biggish ones, but none that would just fit
    without boring it, so I might as well have bored it, IYSWIM.
    I just made a mandrel and pressed the fucker in. I'm used to squeezing a
    large stiff thing into a tight hole.
    No reaming required, according to Mr Hemmings, and it seems like a
    reasonable running fit. The camplate bush is a tad tight, but nothing to
    write home about.
    <Famous last words mode>
    It'll probably free up a bit with some use.
    Ta.
  6. Wicked Uncle Nigel
    JB Guest
    This is as it should be. You being from Yorkshire (rather than God's Own
    County, Lancashire) should know this ;>)
    JB
    JB, Dec 28, 2007
  7. Wicked Uncle Nigel
    JB Guest
    Fairy nuff.
    Yeah, yeah, Oh King Salami!
    <crosses fingers>
    <drops twiglets>
    "it will also brush off when it dries etc..."
    JB
    JB, Dec 28, 2007
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, Beelzebub
    I'm polishing one, even as I type.
  9. Wicked Uncle Nigel
    JB Guest
    I'l bet he has, I'll bet he has too. And "Snap-On" always seemed a little
    too close to "Strap-On" for my tastes.
    I'll stick to Britool. Got to fly the flag you see ;>)
    JB
    JB, Dec 28, 2007
  10. Wicked Uncle Nigel
    JB Guest
    You sir, are the 'Flashman' of the spanners.
    JB
    JB, Dec 28, 2007
  11. Wicked Uncle Nigel
    Eiron Guest
    Bris Tools?
    Eiron, Dec 28, 2007
  12. Wicked Uncle Nigel
    JB Guest
    Tools are *always* porn.
    JB
    JB, Dec 28, 2007
  13. Wicked Uncle Nigel
    Eiron says...
    They're a cut above the others, but always a bit tight on nuts.
    Lozzo
    Triumph Daytona 955i SE (Niged-out)
    Suzuki SV650 K3 (For sale - email for details)
    Honda CBR600 F-W trackbike
    Yamaha SR250 SpazzTrakka
    Suzuki GSX-R750L
    Suzkui TS50X x2
    Lozzo, Dec 28, 2007
  14. Wicked Uncle Nigel
    One trick you can use to get a bush out of a blind hole is to put some oil
    into the hole, then slide a close-fitting bit of rod in and clout it with
    the adjusting stick.
    platypus, Dec 29, 2007
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    Oh aye.
    And if Notrun hadn't kindly drilled a perpendicular hole in the shaft to
    take the kickstart spring, that might even have worked.
    Still, it made an easy place to put the air line for the post-boring
    cleanup.
    Wicked Uncle Nigel, Dec 29, 2007
  16. Sounds like the ukrm version of Are You Being Served's line: "It'll ride
    up with wear...."
    The Older Gentleman, Dec 29, 2007
  17. Wicked Uncle Nigel
    AW Guest
    Hmm. Refurbing the gear box was on my list of things to do this
    winter, had I kept the bike. Sounds beyond my capabilities though!
    It's going to be a lovely bike when you've got it all together and
    then I'll sulk.
    AW, Dec 29, 2007
  18. It'll be a lovely bike for about ten miles, and then he'll be cursing
    it. You're well shot of it, IMHO.
  19. Wicked Uncle Nigel
    AW Guest
    It was quite interesting to compare the Notrun side by side with my
    Morini - similar vintages but the Morini is just light years ahead in
    every way possible.
    AW, Dec 29, 2007
  20. Wicked Uncle Nigel
    SD Guest
    That's not really fair on the Norton - it's not really of a similar
    vintage at all, it's just that they were still making them (badly)
    thirty years after they should have stopped.
    IIRC the CBX is only 3 or 4 years more "modern" than the Morini.
    | ___ Salad Dodger
    |_\_____/_| ..93550../..25068.../..31928.
    SD, Dec 29, 2007
