That damned Beelzebub
Discussion in 'UK Motorcycles' started by DozynSLeepy, Aug 7, 2009.
  1. DozynSLeepy
    Must have been like living in the Marianas Trench
    Hog, Aug 10, 2009
    #41
  2. DozynSLeepy
    Francis Guest
    Not my experience. I replaced (twice) the original Spark500 on my Guzzi
    V11 Sport with a Odissey PC545 and it works fine since.
    I also had to replace the Ducati Energia reg/rec, swapped with a
    Lombardini one: same shit but much cheaper (70€+shipping when Guzzi ask
    for 165€ for the genuine part).
    Francis, Aug 11, 2009
    #42
  3. DozynSLeepy
    Francis Guest
    A lot of Elefant and Ducati owners ugrade the wiring from battery to
    starter with thicker wire, hte original part is undersized.
    #43
  4. DozynSLeepy
    Eddie Guest
    I know. BTDT.
    I did that after swapping the original battery for an Odyssey, but
    before replacing the starter motor brushes. And now the original
    battery's back in, and seems to be fine <fx: fingers crossed>.
    The problem is particularly noticeable on Elefants, where the distance
    from battery, via solenoid, to starter motor is something like 9', IIRC.
    Eddie, Aug 11, 2009
    #44
  5. DozynSLeepy
    Eddie Guest
    Okay... so why did you have to replace it twice?
    On the Elefant mailing list, it's about a 50:50 split between those who
    think Odyssey batteries are the bee's knees, and those who wouldn't use
    one if you paid them. I'm still sitting on the fence.
    Sounds familiar.
    Eddie, Aug 11, 2009
    #45
  6. DozynSLeepy
    Francis Guest
    The original Spark500 lasted 5 years, the second one was killed when the
    reg/rec died letting voltage pass through unregulated (more than 20V at
    3500 rpm), 3 years ago.
    The reg/rec was replaced by an Electrex 451 who also died (short between
    +12 and case): the PC545 battery discharged through it overnight.
    When I disconnected it shows a residual 6V, I put it on the optimate and
    get it back fine.
    AFAIC, it does the job nicely.
    Yes. Shite Italian Electrics, no surprises. :)
    #46
  7. DozynSLeepy
    Eddie Guest
    Yes.
    Refer to this if you're not familiar with the shape of an Elefant:
    http://p1.bikepics.com/pics/2006\10\17\bikepics-703632-full.jpg
    Battery, under seat, somewhere near the vent in the rear right fairing
    panel;
    Cable goes up right side of frame, to rear of tank, crosses under tank,
    continues up left side of frame towards solenoid, which is mounted
    inside the top-left fairing, roughly between indicator and headlight;
    From solenoid, back to the frame under tank, down left side of front
    frame rail, behind sump guard to starter motor terminal, located on the
    right side of bike.
    Those crazy Italians!
    Eddie, Aug 11, 2009
    #47
  8. DozynSLeepy
    Yet you like Rothko - go figure!
    Krusty, Aug 11, 2009
    #48
  9. DozynSLeepy
    #49
  10. DozynSLeepy
    No question about it.
    Ace, Aug 11, 2009
    #50
  11. DozynSLeepy
    Eddie Guest
    Mine looks much better than that, obviously. *cough*
    Uh-huh. The only place it could be further from the battery is if they
    mounted it on the screen. I don't know why. Monsters have it located
    somewhere sensible, on the right side between battery and starter.
    I dread to think. I'm sure it made sense at the time.
    Eddie, Aug 11, 2009
    #51
  12. DozynSLeepy
    boots Guest
    One's a work of art, the other of a deranged mind
    boots, Aug 11, 2009
    #52
  13. DozynSLeepy
    Yupp, that there Rothko bloke must have been very disturbed.
    Ace, Aug 11, 2009
    #53
  14. DozynSLeepy
    Lozzo, Aug 11, 2009
    #54
  15. DozynSLeepy
    Eddie Guest
    There's a reason for that.
    Eddie, Aug 11, 2009
    #55
