Test rides ahoy
Discussion in 'UK Motorcycles' started by simonk, Apr 9, 2005.
  1. simonk
    simonk Guest
    So, the question of what to get to replace the Mille rears its head once
    again ...
    Popped up to George Whites in Slough with Kiran and another mate[1] where
    they had a GSXR750 demonstrator, new this week with only 100 miles on the
    clock.
    Impressions after a short ride: "handles well" in a sit-on-and-go kind of way
    - seemed like the sort of bike that would be very easy to get on with. Not
    too cramped generally, but the footpegs a bit high for my daddy long legs
    legs. Not much power low down, but shed-loads above 9000rpm, with a redline
    at 15000 (not visited). Bit of a contrast to the Mille. Engine a very jerky
    on occasion on the transition between throttle shut and throttle slightly
    open, making for some interesting low-speed turns in town. Brakes work well
    but lack feel compared to the Mille's.
    Overall, very nice. I was sorely tempted ...
    .... until, I blagged a go on Kiran's shiny new GSXR1000 on the way back into
    London. What a ridiculous, pointless, outrageously comfortable, childsplay
    to ride, stupidly powerful machine. New K4s are a good 500 quid less than
    new 750s. I think I know which one I'll be getting.
    Then again, riding behind someone else on my bike did make me realise how
    cool the Mille looks, and what a lovely, lovely noise it makes. When it
    starts. Still, be sad to see it go.
    [1] whose new Repsol replica 05 blade is in my garage. Wonder how easy it is
    to disconnect the odometer ...
    simonk, Apr 9, 2005
  2. simonk
    simonk emerged from their own little world to say
    Assuming it is the usual Honda electronic job then there will probably be a
    3 pin plug under the seat. Follow the weather-proofed wire from the front
    sprocket sensor until it disappears inside the fairing/under the seat. You
    should find a plug where the spur joins into the main bike harness.
    My VFR & CBR6 had the same system. I agreed a deal on the VFR just before a
    trip to the Alps. I told the dealer that it would be sub 16k on my return.
    I had to disconnect the plug about 500 miles before returning home to
    "keep" the promise.
    wessie, Apr 9, 2005
  3. simonk
    Ballistic Guest
    He popped round today and I took it for a spin. These things are just
    bonkers, within 3 minutes of leaving the street I was doing 144mph and I
    think I was in 4th gear.
    It didn't like pulling at low revs but when you had it up a few grand then
    it was OMG JFC time. I'd forgotten how much fun this type of thing is.
    Anyone want to buy a big traillie?
    Ballistic, Apr 10, 2005
  4. simonk
    Kiran Guest
    That was the first time I've ridden your Mille. And I was very impressed,
    even if it was just a short stint. The riding position was excellent and the
    noise....**** knows why you're selling it. Get another one.
    Kiran, Apr 10, 2005
  5. simonk
    simonk Guest
    My abiding memory was going down the M4 under the M25 flyover at what I felt
    sure was about 85, but was in fact 130. I think the bigger screen does quite
    a bit to shield you from the sense of speed - certainly things are getting a
    bit windy on the Mille at those sorts of speeds
    simonk, Apr 10, 2005
  6. simonk
    Kiran Guest
    Actually, I think the speedo's not that accurate. Generally, on the
    motorway, 85-90 will see you past 90% of cars. On the GSXR, it has to be
    about 100, so suggests it is definitely 10% out.
    Kiran, Apr 10, 2005
  7. simonk
    dwb Guest
    When the ticket & summons for 117mph comes through you can confirm it.
    dwb, Apr 10, 2005
