[QUOTE="David Thomas"] Hi All Wonder if anyone can shed any light on a problem I've got on my new (to me) bike, it's a Bandit 600S (2000) with 6K on the clock. The problem is that it won't bleeding start when the engine is hot, the only way to get it going (eventually) is to give it a handful (and I mean shed loads) of revs. I have had the carbs balanced, valve clearances adjusted, idle mixture adjusted & new spark plugs correctly gapped. [/QUOTE] compression test?
