techy monitor stuff
Discussion in 'UK Motorcycles' started by Porl, Nov 6, 2004.
  1. Porl
    Porl Guest
    I just got a new machine which comes with a 17" TFT monitor. But while the
    new machine works with my old crt (as I want it to) the old machine doesn't
    like the TFT. ANyone know of an adatpr that works this way?
    Porl, Nov 6, 2004
  2. Porl
    tallbloke Guest
    What video card in the old machine? Or if it's onboard, the motherboard specs
    will tell you what the chipset is.
    tallbloke, Nov 6, 2004
  3. Porl
    Dan L Guest
    I recently had to replace my 17" CRT and went for a TFT.
    I had to **** about with the resolution settings and refresh rate to get it
    to work.
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R
    Spare Bike 1990 Suzuki TS50X
    BOTAFOT #140, DIAABTCOD #26, BOMB#18 (slow)
    Dan L, Nov 6, 2004
  4. Porl
    porl Guest
    It's Quadra2 fx Gloria 3 or summat. Any use?
    I just get an "incompatable" message.
    porl, Nov 6, 2004
  5. Porl
    tallbloke Guest
    Tried driverguide.com for a later driver?
  6. Porl
    Catman Guest
    You need to reset the resolution / refresh to work with the new monitor.
    Setting to 800x600 at 60Hz using the old monitor, then plug in the new one
    should work. you can then adjust as required.
    www.cuore-sportivo.co.uk
    Catman, Nov 6, 2004
  7. Porl
    porl Guest
    [Applause]
    Thanks, and to all other replies. Even the shit ones.
    porl, Nov 6, 2004
  8. Porl
    Catman Guest
    <fx: bows>
    Two in two days, I think I might have to shut up
    Catman, Nov 6, 2004
  9. Porl
    Porl Guest
    Go for a hat trick and explain why it reboots after loading or trying to
    load mups.sys
    Porl, Nov 6, 2004
  10. Porl
    Spike Guest
    Im assuming that this machine has SP2?
    What make of machie is it? Chaces are that an update of the BIOS will fix
    the problem....
    Gimme a call if youre still having hassle (that is if youve still got my
    phone number...)
    Spike, Nov 6, 2004
  11. Porl
    Porl Guest
    Cheers, I'm not sure if I have. I think it might be academic because after
    reseating the ram I may well just have killed it.
    Hooray!
    Porl, Nov 6, 2004
  12. Porl
    Catman Guest
    This seems to be quite a common issue. Couple of possible fixes:
    1) Go to BIOS and load the basic default settings
    2) Boot from the XP CD and run:
    sfc /scannow
    from the command
    3) Re-install / repair the windows install.
    4) http://www.michaelstevenstech.com/XPrepairinstall.htm#warning2
    On the down side, it *might* be linked to the old capacitor failure thing.
    Your mobo could be fubar, which given what you've posted about
    HTH and I'm not about to break my winning streak.
    Catman, Nov 6, 2004
  13. Porl
    Spike Guest
    You *did* unplug the power cable before you did this, didnt you?....
    Spike, Nov 6, 2004
  14. Porl
    Porl Guest
    As I said it isn't even booting now. It's doing rock all. And yes spike I
    unplugged it :)
    Porl, Nov 6, 2004
  15. Porl
    Porl Guest
    Heh, that almost brought a smile to my face in these trying times.
    Porl, Nov 6, 2004
  16. Porl
    Spike Guest
    Just checking like :)
    Right, so you take all cards out, and all memory and you put back the Vid
    card and the minmum amount of memory (1 stick unless its a dual channel
    memory setup)
    Take the button battery out from the motherboard and leave it out for 5
    minutes. Put it back.
    Does it boot up now?
    Do you get any beeps?...
    When you plug the power cable into the machine, do you hear a slight crackle
    and see the fan "kick"?.. Its *possible* that the PSU is dead..
    If none of these work, and if its a decent make, send the fucker back and
    get them to fix it. Chances are theyll ask you to do that lot before they
    take it back anyhow.
    Spike, Nov 7, 2004
  17. Porl
    Porl Guest
    Well it's a mystery to me. I connected the PSU with a paper clip to see if
    it was working and I got nothing. Then I plugged it back in in frustration
    and stabbed the buttong and it worked perfectly. After 3 hours of messing
    around.
    I hate computers.
    Porl, Nov 7, 2004
  18. Porl
    Steph Guest
    No, mups.sys always comes first.
    Steph, Nov 7, 2004
  19. Porl
    Steph says...
    Which must be a great disappointment for you.
    Lozzo, Nov 7, 2004
  20. Porl
    *snort*
    Pip, Nov 7, 2004
