technique to cover back engine oil cover w/o leaking
Discussion in 'Motorbike Technical Discussion' started by NewBie, May 25, 2004.
  1. NewBie
    NewBie Guest
    Hi,
    I have replaced the oil filter (Suzuki GZ125) and engine oil 3 days ago.
    After covering the oil cover, there is no leaking of oil from the cover. The
    surrounding of the oil cover becomes oily after travel to the next
    destination. I think the cover did not sit correctly. Any advice?
    YC
  2. ahh, a singaporean student motorbicyclist
    there will be an o-ring seal for the cover which may not be sitting in its
    groove properly...or it has fallen out when you take cover off and is lost
    if cover has a groove around it where o-ring seal goes...get another
    if cover has gasket...replace gasket or use proper silicone to seal it
    fulliautomatix, May 27, 2004
