Technical query
Discussion in 'Classic Motorbikes' started by Lozzo, Jun 10, 2005.
  1. Lozzo
    My 14 yr old nephew has a field bike, an old mid 80s KE125.
    His dad has ripped out all the electrics in an attempt to make it a
    simple kick start and go type bike, with no ignition switch. Has anyone
    got a simple wiring diagram I can use to rewire the thing, cos his
    dad's pissed off and left him to do it alone?
    My knowledge of bike electrics isn't that great.
    Lozzo, Jun 10, 2005
  2. I have a genuine factory manual for the old (1970s) KH125, which used
    the same engine. I can't see that the wiring is going to be different.
    I'm off to Colombie tomorrow, but if you get a snail mail addie to me,
    I'll ask The Doctor to pop it in the post on Monday, as long as it gets
    popped back once used.
    The Older Gentleman, Jun 11, 2005
  3. Lozzo
    Alternatively, just hand it to me this afternoon and the spic can pick
    it up from here or I can drop it off at PixieCentral in the next couple
    of weeks...
    Timo Geusch, Jun 11, 2005
  4. Lozzo
    Buzby Guest
    Lucky sod. Just keep yer head down when the bullets start to fly!
    Buzby, Jun 11, 2005
  5. He may want it sooner than that. I'll wait and see what the spiccy one
    says.
  6. Lozzo
    The Older Gentleman says...
    I have access to a proper KE125 wiring diagram, I can use that. Thanks
    for the offer though.
    What I'm after is a simplified diagram so we can run this thing sans
    lights/indicators/horn/ignition switch etc. At the moment there is no
    wiring at all cos my dickhead bruv-in-law has chucked the old wiring
    loom out. My knowledge of rewiring bikes is minimal and I do get a bit
    confused with what bits are needed and what aren't. I'm not so bad at
    diagnosing and repairing electical faults though.
    Lozzo, Jun 11, 2005
  7. Lozzo wrote
    Piece of piss.
    From what you have said, all you need to do is add a cut out switch.
    Easy, honest.
    steve auvache, Jun 11, 2005
  8. Is it a simple magneto&coil/points like my old Suzi A100II?
    IIRC it goes something like:
    Coil
    \ /\----->Spark
    \ Magneto coil |------------
    / \/Points = Condenser
    I've not got that exactly right (can't remember which bits
    actually connect to ground) but you should see how those few pieces fit
    together in the original diagram. Kill button just shorts out the points
    (i.e. normally-open switch in parallel with the points and the condenser,
    often just the one wire from the "hot" side which is shorted to the
    handlebar (=ground) by the switch).
    Rocket science it ain't.
    Brunel University. Room 40-1-B12, CERN
    GSX600F, RG250WD. "You Porsche. Me pass!" DoD #484 JKLO# 003, 005
    Dr Ivan D. Reid, Jun 11, 2005
  9. Lozzo
    Dr Ivan D. Reid says...
    I knew someone like you would come up with summat, cheers, Ivan.
    Lozzo, Jun 11, 2005
  10. Lozzo
    Paul - xxx Guest
    Lozzo came up with the following;:
    http://www.ronayers.com/fiche/frames.cfm?man=ka&groupid=5330&parent=5240
    Might help, though it's for a KE100.
    Indeed, the website http://www.ronayers.com/fiche/getdesc.cfm?man=ka with ya
    for Yamaha, su for Suzuki and guess what for Honda at the end of the url
    might help anyone wiith a diagram or two.
    Hope it helps someone ... ;)
    Paul - xxx, Jun 12, 2005
  11. Lozzo
    Paul - xxx Guest
    Paul - xxx came up with the following;:
    Bad form but ...
    http://www.buykawasaki.com/Default....VIChooseVehicle.asp?intCatalogID=2&intParts=1
    Has good infor for KE 125 ... ;)
  12. Lozzo
    Salad Dodger Guest
    Sir wants a TS185/250, sir does.
    Simply pull off all the loom, except for the two-core cable from the
    magneto to the CDI box, two wires to the coil, and an HT lead to the
    plug.
    | ___ Salad Dodger
    |_\_____/_| ..75830../..18846.../..3214./.19406
    \|^|/ ANORAK#17 IbB#4
    '^' RBR Landmarks: 24 Pts: 400 Miles: 1589
    Salad Dodger, Jun 12, 2005
  13. Looks like the B15 model has CDI with the capacitor charged up via
    high-voltage coils in the flywheel, so that's a wee bit different to the
    magneto models.
    Dr Ivan D. Reid, Jun 13, 2005
  14. Oops, that was the KE100 info that Paul posted...
