Tech Q: spacing of indicators
Discussion in 'UK Motorcycles' started by SIRPip, Mar 31, 2011.
  1. SIRPip
    SIRPip Guest
    I've been looking at a bike rear light unit which has LED bulbs and
    indicators buit in to the extreme corners. Fantastic on the face of it
    - no more bulbs blown by vibes, but better yet, a way to get rid of the
    sticky-out indicators that foul throwovers. However, in the back of my
    mind is a minimum spacing - do indicators have to be 300mm apart or is
    my dodgy memory playing tricks?
    I've checked the online MoT tester's manual and there's no mention of
    it there and I can't find C&U regs for bikes. There's Type Approval
    Euro-documents and the most relevant section mentions a minimum gap of
    180mm between the closest lighted areas. There isn't 180mm between
    these, for sure:
    http://cgi.ebay.co.uk/230498990877
    But the thing is E-marked, although the seller cautions buyers it is
    their responsibility to check compliance with their countries' regs. I
    don't suppose a MoT tester would kick it out, neither would Plod tug me
    for it ... probably. Might be one more thing to stick me for if
    tugged, however.
    What does the FOAK reckon?
  2. SIRPip
    SteveH Guest
    I'd be more worried about half blind fuckers not noticing the flashing
    indicator, as it's so close to the tail light - seems to be a big issue
    with LEDs in particular.
    Look at the tail lights on a recent Passat - when the tail lights are
    on, it's incredibly hard to see the indicator.
    I did read an explanation for it somewhere, but can't recall where.
    SteveH, Mar 31, 2011
  3. what's behind you doesn't matter
    steve auvache, Mar 31, 2011
  4. SIRPip
    Dan L Guest
    This would be my concern too.
    My lad fitted an led tail tight incorporating indicators on his VFR400.
    I've never really liked it, although it does make the back end tidier.
    Dan L, Mar 31, 2011
  5. SIRPip
    Adrian Guest
    C&U isn't online, but the Road Vehicle Lighting Regulations are.
    http://www.legislation.gov.uk/uksi/1989/1796/schedule/7/made
    Adrian, Mar 31, 2011
  6. SIRPip
    Spotted some on a Gixxer at the weekend.
    Gash.
    CT, Mar 31, 2011
  7. SIRPip
    SIRPip Guest
  8. SIRPip
    SIRPip Guest
    Shame. I thought it was a neat solution, but it appears that apart
    from the Style Police standpoint, a rethink is in order.
  9. SIRPip
    SIRPip Guest
    Champ used to say that - until he was taken roughly from behind at
    Oulton Park.
  10. SIRPip
    SIRPip Guest
    Good points. Not legal anyway, and whilst not being overly concerned
    about that, giving an excuse for a pull is never a good idea.
  11. SIRPip
    SIRPip Guest
    You're quite right, you know. We've discussed this at home, wrt
    several makes of car which have gone over to LED rear lights.
    Blindingly apparent in darkness, much less so in daylight and
    particularly in strong sunlight.
    Does the Passat have a circular indicator in the middle of a ring of
    red LEDs for the tail light? If it is, I'm in agreement. The
    explanation is something to do with perceived contrast, I think. A 21W
    flasher bulb is always going to be visible next to a 5W tail bulb, but
    with LEDs it doesn't seem to work that way.
  12. SIRPip
    Absobloodylutely. They seem to have a much narrower angle of
    obviousness too. And it's not just the rears, I've noticed it with
    front indicators too when there's bright sunlight reflecting off the
    headlights.
    Krusty, Mar 31, 2011
  13. SIRPip
    <dwb>
    </dwb>
  14. SIRPip
    Scraggy Guest
    I rather like the front, daylight running LED's on the bigger Audis.
    they dim right down when the indicator is in use. A very sensible idea
    IMHO.
    Scraggy, Mar 31, 2011
  15. SIRPip
    Catman Guest
    Could this be because (AIUI) they use PWM to modify the brightness of
    the brake / tail lights with LED's? I can see the pulses being in sync
    and creating the visibility issues that I can certainly relate to. Range
    Rovers are similar IME.
    #www.cuore-sportivo.co.uk
    Catman, Mar 31, 2011
  16. SIRPip
    SteveH Guest
    Can't remember - might be the other way around.
    But the problem still exists, either way.
  17. SIRPip
    Hog, Mar 31, 2011
  18. SIRPip
    SIRPip Guest
  19. SIRPip
    SIRPip Guest
    <Loz>
    </loz>
  20. SIRPip
    Fucking hurt, that did - my daughter wasn't too impressed either.
    Lozzo
    they churn out)
    Lozzo, Mar 31, 2011
