Tanks? Don't talk to me about tanks...
Discussion in 'UK Motorcycles' started by Nigel Eaton, Jan 23, 2005.
  1. It was somewhere around Barstow, on the edge of the desert, when the
    wahey!
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Jan 24, 2005
    #41
  2. Nigel Eaton
    rb Guest
    Well! If you are going to give out clues like that then you might just
    as well go round and do the job for them.
    rb, Jan 24, 2005
    #42
  3. Nigel Eaton
    Preston Kemp Guest
    Bidet standard's softer & smells nicer.
    Preston Kemp, Jan 24, 2005
    #43
  4. Nigel Eaton
    You'll be more popular than that bloke who collects and runs jet engines
    in his garden.
    Muck, Jan 24, 2005
    #44
  5. Nigel Eaton
    Verdigris Guest
    Ooh! You mean I'll soon have room to fix the Tiger?
    Verdigris, Jan 24, 2005
    #45
  6. Nigel Eaton
    Verdigris Guest
    Some of the big, commercial tumble-driers are heated by gas, so a spark
    probably wouldn't be necessary.
    #46
  7. Nigel Eaton
    platypus was seen penning the following ode to ... whatever:
    .... followed by some lead fishing weights or so, then pack the tank in
    lots of old blankets and chuck it into a cement mixer for several
    hours. Should clean out the tank nicely and coat the tank's inside
    with lead at the same time.
    Supposed to be a popular tank cleaning method in the Fatherland,
    this.
    Timo Geusch, Jan 24, 2005
    #47
  8. Nigel Eaton
    Nigel Eaton was seen penning the following ode to ... whatever:
    Speaking of which, would it be possible to drop by in the next four
    weeks or so so we could make an attempt to drill out the various bolts
    that are corroded into inaccessible or expensive parts of the Pan?
    #48
  9. Nigel Eaton
    I add a few teaspoons of EDTA [1] to the distilled water bottle I use for
    topping up. An apple a day and all that.
    [1] I'm pretty sure EDTA is one of the constituents of BattAid.
    sweller, Jan 24, 2005
    #49
  10. Nigel Eaton
    Only because some lazy cow hasn't done the pots.
    #50
  11. Nigel Eaton
    Fix the tank between the centres [1] or will it hit the bed?
    [1] Off centre would be good.
    #51
  12. Nigel Eaton
    Salad Dodger Guest
    Panzerkleeneruppenfuhrer:
    "Ve need a bigger zement mixer, and lots off blenkits."
    Salad Dodger, Jan 24, 2005
    #52
  13. Nigel Eaton
    Martin Guest
    Sounds like my father, that also includes small (.020 cu inch)
    unsilenced 2-stroke model plane engines, slightly larger 4-stroke poorly
    silenced model plane engines, angle grinders, welders (look great at
    night-darkLIGHT-dark-LIGHT-LIGHT-LIGHT-dark-LIGHT-LIGHT-LIIIIIIIIIGHT-dark)
    Shite ole 2-smoke bike motors (see sig), shite old bikes, shite old cars
    etc etc.
    Toast of the street our family.
    Martin:
    VTR1000 Firestorm
    Martin, Jan 24, 2005
    #53
  14. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Timo Geusch
    Yep. I'm away for a week from Saturday, but other than that I should be
    around and about.
    Nigel Eaton, Jan 24, 2005
    #54
  15. Nigel Eaton
    Lady Nina Guest
    The dishwasher was full of bike bits.
    Lady Nina, Jan 24, 2005
    #55
  16. Nigel Eaton
    I think that the regs require model planes to be about 82db at 7 meters
    or something, this is at full throttle.
    Heh.. 2 stroke motors seem to be a favorite hate for some people. I
    noticed this when flying my 2 stroke model plane at a local flying
    field. A bloke came over from a near by house, and complained, even
    though my plane was within the noise limits. He didn't seem to mind the
    noisier 4 stroke plane that was flying.
    Muck, Jan 24, 2005
    #56
  17. Nigel Eaton
    Martin Guest
    Hmmmm, I'll make sure to take the dB meter next time.
    He's jealous of the lurvely castor oil smell off em, that works for me,
    and the oozing oil down the side of the plane, mmmmmmmm.
    Martin:
    VTR1000 Firestorm
    #57
  18. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    OK, the more notice the better at the moment. So that's a nice change,
    then...
    *Loads* of time.
    Temporarily homeless.
    #58
  19. Nigel Eaton
    82 db is a maximum, and it has to be measured with the plane held 1m off
    the ground and measured from the back, front, left and right from 7
    meters away.
    You can loose a flying field if your plane is too loud.
    Heh, I like that too.. apart from the plane being slimy and icky. Castor
    is kinder to the engines though. :)
    Muck, Jan 24, 2005
    #59
  20. Nigel Eaton
    Martin Guest
    The current field is next door to RR's engine testing facility so it's
    not too much of a problem.
    For hands that fly aeries to feel soft as your face, choose mild yellow
    castor oiiilll.
    Martin:
    VTR1000 Firestorm
    #60
