Tanks? Don't talk to me about tanks...
Discussion in 'UK Motorcycles' started by Nigel Eaton, Jan 23, 2005.
  1. Nigel Eaton
    Nigel Eaton Guest
    So today was the day that I decided to properly clean out the tank on
    the BlingMobile. The problem is that some pillock has coated the inside
    of the tank with some sort of sealant. Only it's crap. It's a cream
    colour (El Spic suggested it's a septic product called "Kreme"). And it
    almost (but not quite) sticks to the inside of the tank.
    The upshot is that great lumps of it fall off and block the fuel tap.
    Washing the tank out with hot soapy water got quite a lot of it out. A
    steam cleaner got quite a bit more. Advanced gynaecology through the
    fuel level sender hole got even more.
    I was considering hacking a hole in the bottom of the tank, then
    persuading Pip to weld it back, but his obvious enthusiasm for the
    project dissuaded me.
    So I'm going to dry the fucking thing out, and hit it with some Petseal.
    We'll see what happens.
    I love this bike, but it's a real pain in the arse sometimes...
  2. Let it dry, then pour in a handful of pea gravel. Shake it like ****
    for a while. Rest and repeat. That will grit blast a lot of the worst
    of it off prior to petsealing it.
    Like a good woman...
    Simon Atkinson, Jan 23, 2005
  3. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Simon Atkinson
    I like that idea. A lot. I shall do that. Thank 'ee master.
    Well, quite.
  4. Also builds up your arms like a night in a car park with Sir Tony.
    Off.
  5. Nigel Eaton
    Or old nuts and bolts. Wedge it into the tumble drier with a couple of old
    pillows, and give it a few hours on the cool setting.
    platypus, Jan 23, 2005
  6. Nuts and bolts sounds good - Tumble drier could be a bit gentle
    compared to a fully trained Morris dancer giving it a good shaking as
    if it were a pigs bladder on a stick.
  7. Nigel Eaton
    Excellent idea, if the tank isn't too big to fit into the tumble drier.
    Muck, Jan 23, 2005
  8. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    Probably easier to get back out than gravel, on reflection.
    I don't think this tank will fit in the tumble drier. I might have to
    rig something up.
  9. Nigel Eaton
    Depends how long the Fully Trained Morris Dancer can keep it up for.
  10. Nigel Eaton
    Nigel Eaton Guest
    Not long, these days. Usually just long enough, in fact.
    This one may need mechanical assistance.
  11. Nigel Eaton
    platypus emerged from their own little world to say
    www.viagra.com
    wessie, Jan 23, 2005
  12. Nigel Eaton
    Concrete mixer?
    Muck, Jan 23, 2005
  13. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, wessie
    It's an idea, but it'd be a bit expensive.
    I think I'll use the nuts and bolts.
  14. Nigel Eaton
    Christofire Guest
    Attach it to a hardley ableson. Failing that, chuck on the dash of a
    metro and get it up past 70. IME that'll shake it like it's on a
    jackhammer.
    Christofire, Jan 23, 2005
  15. Nigel Eaton
    A year or so back, somebody on here recommended an outfit that would
    chemically dung out your tank, but I can't find it on google.
    Wait one, I've just had a thought.
    Yep, here it is:
    http://groups.google.co.uk/groups?q...2bh3$1i1il2$&rnum=1
  16. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Muck
    <looks in garden>
    And we have a winner! I'd completely forgotten I'd still got that.
    That should drive the neighbours barmy tomorrow, then.
  17. Nigel Eaton
    Nigel Eaton Guest
    That looks good, but I think they'd still have a problem with this
    "Kreme" shit. I'll give the tumbling a go, and see what happens when I
    Petseal it.
    Nigel Eaton, Jan 24, 2005
  18. Nigel Eaton
    rb Guest
    Laundrette. YKIMS.
    rb, Jan 24, 2005
  19. Nigel Eaton
    Lady Nina Guest
    On behalf of the female monotreme can I just say 'keep away from my
    tumble dryer'.
    Lady Nina, Jan 24, 2005
  20. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Lady Nina
    (sigh)
    And there you go, reinforcing tired sexist stereotypes. Frankly, I
    expected rather better from you.
