Taking the front wheel off a KZRX1100
Discussion in 'UK Motorcycles' started by Vas, Oct 29, 2005.
  1. Vas
    Vas Guest
    How do I do it? I've seen the guys in the workshops do it whilst
    changing the front tyres, but I can't remember how they did it.
    Vas.
    Vas, Oct 29, 2005
  2. Vas
    Vas scribbled on the back of a napkin:
    (1) Get the front of the bike off the ground.
    (2) Take out wheel.
    Where's the problem?
    Timo Geusch, Oct 29, 2005
  3. Vas
    If you can't just look at it and fathom it out for yourself then you
    shouldn't be attempting the job.
    Andy Bonwick, Oct 29, 2005
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, Vas
    Angle grinder.
    Wicked Uncle Nigel, Oct 29, 2005
  5. Vas
    Big Dave Guest
    Start undoing and removing all nuts and bolts in the general area of the
    front end of the bike and eventually the front wheel will fall out of its
    own accord.
    Big Dave, Oct 29, 2005
  6. Vas
    First things first, Mr. Deferens.
    How do you intend to support the front end of your mighty motorcycle
    once the wheel isn't there to do it?
    Pip, Oct 29, 2005
  7. Vas
    muddy Guest
    A sky hook?
    muddy, Oct 29, 2005
  8. Vas
    Vas Guest
    The problem is, does the spindle unscrew like a long bolt, or is it
    just the pinch bolts holding it in place?
    Vas, Nov 1, 2005
  9. Vas
    Vas Guest
    If you can't give me a sensible answer, then don't fucking bother. Stop
    trying to be a smart arse.
    The problem is, the spindle is not moving with the pinch bolts undone.
    With these undone, does it just slide out or do I have to unscrew it
    first.
    Vas, Nov 1, 2005
  10. Vas
    Vas Guest
    That's taken care of.
    Vas, Nov 1, 2005
  11. How do I do it? I've seen the guys in the workshops do it whilst
    Assuming it's the same as my 12,
    1) Remove both brake calipers and the spedo cable guide.
    2) Undo pinch bolts on the throttle side. Leave the ones on the clutch
    side done up.
    3) Using a large hex key undo the spindle from the throttle side.
    4) Hold wheel and remove spindle.
    If you don't have a hex key large enough to unscrew the spindle you can
    do it from the clutch side and drift the spindle out. (Having undone
    the pinch bolts after removing the clutch side hex nut but before
    drifting spindle out)
    __
    RobK
    ZRX1200R XJ600S
    robk200uk.mung, Nov 1, 2005
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, Vas
    Oh bless.
    Here you go diddums, have your rattle back.
    Wicked Uncle Nigel, Nov 1, 2005
  13. They undid the wheel nut(s).
    Is it really that hard to figure out? If you can't even work out how to
    remove a wheel, I suggest that you don't touch it.
    The Older Gentleman, Nov 1, 2005
  14. Vas
    Vas Guest
    At last a sensible answer.
    That's all I needed, thanks.
    Vas.
    Vas, Nov 2, 2005
  15. Vas
    Vas Guest
    I expect this kind of talk off 16 year olds, trying to be smart arses.
    If you want to be childish carry on.
    I asked a simple question, and hoped to get a simple answer (thanks to
    RobK). I'm obviously in the wrong place to get sensible answers.
    How do people learn if you don't ask.
    Vas.
    Vas, Nov 2, 2005
  16. Vas
    I'd say the sensible answers were the ones suggesting you leave it to
    someone who knows what they're doing. But anyway, if you're going to be
    putting it all back together yourself, ffs make sure you test the front
    brake properly before riding off anywhere. It's very easy to do
    something daft like sliding a disk in between the pistons & pad rather
    than between the pads themselves. Doing that could leave you very dead.
    Krusty, Nov 2, 2005
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique, Vas
    What is, YTC?
    Leave some context in, FFS.
    Wicked Uncle Nigel, Nov 2, 2005
  18. Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    Well, with a bit of luck his front wheel will fall off at speed and
    he'll die.
  19. Vas
    Vas Guest
    In order to try and calm this down a little, I'll explain a little
    more on why I posted.
    Firstly, I can work a newsreader, unfortunatley I have only got access
    to this usenet group through Google.
    Secondly, I had tried to take off the wheel already, but with both
    pinch bolts off, the spindle was still not unscrewing. My thought was,
    "have I missed something here?" I wrote my original question in a
    hurry. Maybe I should have taken more time to say what I had tried
    already. Maybe I should have refraised my question a little more,
    maybe.
    I do not warrant the fucking abuse by a bunch of small minded
    aresholes, who think they're funny by hurling sarcastic comments. You
    sound like a bunch of teenagers trying to show off to each other. Grow
    up!
    When someone asks a question, how about a little bit of courtesy, no
    different to a nod or a wave when you pass another biker on the road.
    Bastards.
    Vas, Nov 2, 2005
  20. Vas
    If that's your way of trying to calm things down, I'd hate to see what
    you do to stir them up.
    Krusty, Nov 2, 2005
