Synthetic Lubricant Advice Needed.
Discussion in 'Australian Motorcycles' started by Frank, Feb 18, 2004.
  1. Frank
    Frank Guest
    Hi again to all you knowledgable folk.
    Just wondered whether I should change to synthetic lubricant
    in my Suzuki GS500E with 7500 km on the clock. It's had a
    good thrashing on mineral oil, and is probably well bedded in
    by now. Runs sweet, but does have a flat spot at low revs
    when accelerating. Dealer says it's normal for the model. ??
    If synthetic is considered a good idea, what's the best brand?
    (Mobil 1 ?) I use the bike mainly on motorways at 100 kph
    but about 25% of the time it's around town.
    TIA,
    Frank.
    Frank, Feb 18, 2004
  2. In aus.motorcycles on Wed, 18 Feb 2004 17:08:40 +1300
    Dunno. It's not a bike that's massively hard on oil, I don't think
    there's a lot of need really. Your use isn't that hard either.
    Changing it every 5000km is the key, dino oil or not...
    If you think you will keep the bike a long time, thrash it on tours and
    track days a lot, make it carry heavy weights[1] and are willing to
    wear the cost of synthetic oil that often, then go for it.
    If not, then buy decent normal oil, and change that every 5000km.
    Zebee
    [1] in other words treat it like a certain synthetic-eating high mileage
    van-vulnerable spada....
    Zebee Johnstone, Feb 18, 2004
  3. Frank
    FuTAnT Guest
    I'de just put Motul 5100 on it every 5000 kays or so. If you want to go up
    to Synthetic the Mobil Racing 4T is great stuff and not too expensive. If
    you start using Motul 8100 it costs a friggin fortune!
    Cam
    '03 954
    FuTAnT, Feb 18, 2004
  4. Frank
    Frank Guest
    Thanks for your advice guys.
    Cheers,
    Frank.
    Frank, Feb 18, 2004
  5. Frank
    Mike.S Guest
    Scuse these guys, they don't answer at a whim, they might be out buying beer or
    something, so be patient ffs!!
    If the bikes had about 7.5k kms on it (hopefully with regular changes), then by all
    means run it on semi synth to synth. i hear that motul make some good (and expen$ive oils)
    I use the shel helix stuff from a dark seagreen bottle, and dont suffer any slipage.
    Mobile 1, you talking 4T (i think thats its name) thats made for bikes, or the car stuff?
    Either way they both seem to go well *smirk*.
    Mike.S
    Mike.S, Feb 18, 2004
  6. Frank
    FuTAnT Guest
    Aye, but the new Mobil 1 for cars has apparently now got friction modifiers
    in it definately and once and for all making it not suitable for motorcycle
    use. (dry clutch excepted I guess) Maybe this will end the debate :p
    Cam
    '03 954
  7. Frank
    Mike.S Guest
    When did that start happening?
    Someone will charge ahead like a raging bull, i'm sure of it!
    Mike.S
  8. Frank
    FuTAnT Guest
    Not too long ago. Mobil have changed the car formula (so it says on the
    outside of the bottle) and changed the packaging. The bike stuff also has a
    change of packaging, not sure about a formula change though.
  9. Frank
    Smee Guest
    Go the semi synthetic
    seems to work well for parallel twins .
    Smee, Feb 18, 2004
  10. Frank
    Frank Guest
    Willdo. Thanks to everyone for the help.
    I've been riding m/cycles for about 45 years, (yep I'm an oldie)
    but am still learning, and someone had told me synthetic lubricants
    can stuff clutches on some bikes, so I thought I'd ask those who
    are using the stuff regularly.
    Just realised the odometer is in miles not kilometres, so will
    change oil at 3000 miles in future. Wonder why the speedo
    has miles per hour AND kph. It's a 98 model sold new in NZ.
    Cheers,
    Frank.
    Frank, Feb 18, 2004
  11. Frank
    Johnnie5 Guest
    if they have friction modifiers in the oil then you can have clutch slippage
    probs
    for the world wide market 1 less part to stock for different countries
    and also useful when travelling between countries where one is MPH and 1 is
    KPH
    Johnnie5, Feb 19, 2004
