Swinging arm bushes ...
Discussion in 'Classic Motorbikes' started by M J Carley, Mar 31, 2008.
  1. M J Carley
    ginge Guest
    No, how about California?
    http://maps.google.co.uk/maps?
    f=q&hl=en&geocode=&q=california+derby&ie=UTF8&ll=52.916782,-1.497488
    &spn=0.006676,0.014291&t=h&z=16&iwloc=addr
    I reckon California to Melbourne is do-able in 20 mins.
    ginge, Apr 1, 2008
  2. M J Carley
    M J Carley Guest
    That's part of what I did yesterday: A40, B4452 to Cirencester and
    then down.
    M J Carley, Apr 1, 2008
  3. ...and as we all know, in Pennsylvania the way to Paradise is through
    Intercourse.
    Dr Ivan D. Reid, Apr 1, 2008
  4. M J Carley
    They'll warm up as soon as they contact the swinging arm and nip up if
    he hasn't got enough clearance.
    Checking the clearances between an ambient temperature swinging arm
    and a similar temperature bush is always a good plan because you can
    soon work out how much the bush will shrink when you freeze it and
    you'll then know if you're wasting your time or not.
    No way would I fit those bushes until I knew how much interference
    there was going to be between the bush and swinging arm and how much
    the bush would close up when fitted. If the clearance between the bush
    and swinging arm spindle is going to be a bit tight after fitting it's
    easier to increase the clearance before fitting rather than after.
    Andy Bonwick, Apr 1, 2008
  5. M J Carley
    Great. Do they need reaming (fnaar) after fitting to ensure they're
    dead in line and the right size?
  6. M J Carley
    M J Carley Guest
    Nobody mentioned reaming, although the ones that came out of the
    swinging arm slide into the arm but not onto the spindle; the new
    ones slide onto the spindle, but not into the arm.
  7. M J Carley
    Ace, Apr 1, 2008
  8. M J Carley
    A.Clews Guest
    Stop, please stop!!! You're all reminding me horribly of my Uncle Norman,
    who was always advising pointless alternative routes for journeys I knew
    like the back of my hand. ;-)
    A.Clews, Apr 2, 2008
  9. M J Carley
    M J Carley Guest
    But it's not pointless: it lets you ride your bike on roads you might
    like riding a bike on.
    M J Carley, Apr 2, 2008
