SW-Motech fore-mounted pannier racks
Discussion in 'UK Motorcycles' started by Gyp, May 19, 2011.
  1. Gyp
    Thomas Guest
    Ah yes. I was thinking tee intersection, or too fast. "Approaching"
    would translate more appropriately here as "merging."
    Thomas, May 21, 2011
    #41
  2. Gyp
    Beav Guest
    Safer, but there's nothing wrong with a bit of danger, biker boy.
    Beav, May 22, 2011
    #42
  3. Gyp
    Beav Guest
    Haven't you ever seen the cyclists who have panniers strapped the the forks
    of their bikes? I've not seen any evidence that a side wind deposits them in
    hedges. Which is a shame.
    Beav, May 22, 2011
    #43
  4. Gyp
    Beav Guest
    I thought this one
    "Failure to yield to oncoming train 80 euro fine" was a bit redundant. What
    bits would pay the fine after being hit by a train?
    Beav, May 22, 2011
    #44
  5. Gyp
    Scraggy Guest
    Think also of the priority system.
    Scenario; a N,S,E,W cross roads. The 'main' road is the S & E arms of
    the cross, and prioritised with appropriate signage.
    Approaching the cross roads from the E, you are on the priority road,
    but convention says you will indicate left(right from the S) even though
    you are on the priority road. Belt & Braces approach to safety see?
    One further rule, any manoeuvre that involves crossing a line must be
    indicated, therefore overtaking, sorry, passing :), requires both out
    and in signals.
    Scraggy, May 22, 2011
    #45
  6. Gyp
    Scraggy Guest
    Don't say the German aren't thorough in rooting out the causes of
    accidents;
    "August 2, 1982 – Ostercappeln, Germany: Two drunk British Army soldiers
    steal a tank at the Osnabrück barracks and crash into the oncoming D
    15233 after the tank has been driven on the Rollbahn railway tracks.
    Both engines of the train and five cars derail, the tank is completely
    destroyed. 23 are injured, the two soldiers are instantly killed."
    #46
  7. Gyp
    Thomas Guest
    Yeah. The law says "Thou shalt signal," even when there is no legal
    alternative. The last time I was stopped by plod, they cited me for
    not indicating. I cried, "But I was in the Left Turn Only lane, I
    _had_ to turn left! It would be illegal for me do do anything else."
    Didn't matter to them. Using that logic says you need to indicate
    every time you go around a bend in the road.
    Thomas, May 22, 2011
    #47
  8. Gyp
    Catman Guest
    Curiously I was told many moons ago that if I did that signal on my
    driving test, I would probably get failed (for lack of observation)
    #www.cuore-sportivo.co.uk
    Catman, May 22, 2011
    #48
  9. Gyp
    Yeah, UK plod drivers are taught, according to Roadcraft, that Thou
    Shalt Signal only when there's someone who _might_ benefit from it -
    if you're not sure then you're not doing a good enough job of looking
    out for the someone.
    Ace, May 22, 2011
    #49
  10. Gyp
    Catman Guest
    Ditto in IAM
    #50
  11. Gyp
    Well duh.
    OK, so maybe not everyone knows that Roadcraft is also the IAM bible.
    And Rospa too.
    Ace, May 22, 2011
    #51
  12. Gyp
    Beav Guest
    You shouldn't signal when doing a U-Turn either for the same reason.
    Beav, May 23, 2011
    #52
  13. Gyp
    Catman Guest
    Yeah, fair point.
    Catman, May 23, 2011
    #53
  14. It's what I was taught, certainly.
    Grimly Curmudgeon, May 24, 2011
    #54
