SV650 Clutch dragging
Discussion in 'Australian Motorcycles' started by Yomama, Jan 10, 2005.
  1. Yomama
    Yomama Guest
    The clutch on my bike (sv650s) is dragging a bit when the lever is pulled
    all the way in. I adjusted the clutch as per the suzuki workshop manual,
    but still have the same problem. The transmission is a impossible to get
    into netral without killing the engine first.
    What do I need to do to fix this problem?
    thanks.
  2. Yomama
    SmeeR11S Guest
    How many kms had it done?
    How old is the bike?
    Have you changed the oil recently?
    If I recall coreectly your clutch is bathed in the same engine oil so if
    you haven't changed the oil recently then that could be a problem.
    Clutch plates could be stuck thgether.
    More info required.
    SmeeR11S, Jan 10, 2005
  3. Yomama
    MickK Guest
    Hello, Yomama!
    You wrote on Mon, 10 Jan 2005 22:37:11 +1000:
    Y> The clutch on my bike (sv650s) is dragging a bit when the lever is
    Y> pulled all the way in. I adjusted the clutch as per the suzuki workshop
    Y> manual, but still have the same problem. The transmission is a
    Y> impossible to get into netral without killing the engine first.
    Y> What do I need to do to fix this problem?
    You may want to pose this question in a SV specific forum. Try www.svdownunder.com. Someone there is bound to have had the same problem.
    MickK, Jan 10, 2005
  4. Yomama
    Conehead Guest
    Oil change.
    Conehead
    "I've already lost the argument, I'm now just fighting a rear-guard action."
    Gerry, being more honest than most
    ..au...
    Conehead, Jan 11, 2005
  5. Yomama
    Yomama Guest
    Thanks for the link.
    As for more info, bike is a 99 model (built 12/98) has 74000km on it. I
    just changed the oil and filter last weekend.
    Yomama, Jan 11, 2005
  6. ..au...
    Your oil must have been *really* black!
    Postman Pat
    Pat Heslewood, Jan 11, 2005
  7. Yomama
    Conehead Guest
    Bike change, then.
  8. Yomama
    Yomama Guest
    Oil wan't that bad, not where near as black as the oil from my TRX after
    2000km. It had been changed at 71 400 km.
  9. Yomama
    smack Guest
    and more importantly, what city are you in
    shithead
    smack, Jan 11, 2005
  10. Yomama
    SmeeR11S Guest
    You'll keep
    :p
    SmeeR11S, Jan 12, 2005
  11. Yomama
    Biggus... Guest
    I just changed the oil and filter last weekend.
    Thats when the issue started?? So change the oil to something else.
    what oil r u using?
    Biggus..., Jan 12, 2005
  12. Yomama
    Yomama Guest
    Using Shell SX4. Problem existed even before the oil change.
    I might just pull the clutch apart and get the steel plates sand blasted if
    they look glazed, if no, I think I'll just put up with it.
    Yomama, Jan 12, 2005
  13. Yomama
    Biggus... Guest
    or just rub them on sandpaper, or concrete like thousands of others
    do... Or just replace the lot
  14. Yomama
    Andrew D Guest
    Friend of mine has a SV650S with similar mileage which had a similar
    problems. Problem was shagged clutch cable.
    Andrew
    Andrew D, Jan 15, 2005
  15. Yomama
    Johnnie5 Guest
    Huh ?
    the job of the cable is to activate the clutch
    clutch cables break
    clutch cables stretch which will mean you run out of adjustment
    dragging clutch that is adjusted correctly would often mean buggered clutch
    with
    likely warped clutch plates
    as conehead suggested oil first , then of course you do have it adjusted
    correctly
    as in you have checked it again ??
    Johnnie5, Jan 15, 2005
  16. Yomama
    Yomama Guest
    Shit, I should have thought of the cable earlier. I adjusted the clutch
    leaver until there was almost no play in the lever and checked for drag.
    Low and behold, it's gone, cable obviously was stretched.. I'll have to
    pick up a new cable up on the way home on monday.
    thanks.
    Yomama, Jan 16, 2005
