SV Model differences?
Discussion in 'UK Motorcycles' started by curium, Jan 27, 2004.
  1. curium
    curium Guest
    I've managed to get a cheap Haynes, dated '99-'02.
    Does anyone know if the '03 SV650S has any major differences from its
    predecessors except for cosmetics?
    Thanks in advance.
  2. curium
    curium Guest
    I don't know if this means much but Bridgestone give the option of selecting
    either SV650S (02) or SV650S (03) on their tyre selector applet.
    Do the two have different tyre sizes?
    Thanks in advance.
  3. curium
    Mike Guest
    I think one of them, the more recent model iirc, must be leaned
    over very slightly off vertical, when ridden by a dwarf whom
    wants to GHKD.
    No worries.
    Mike, Jan 27, 2004
  4. curium
    Ginge Guest
    Yes, the newer shape ones got several mechanical changes.. forks, frame,
    and I think cooling system... Fuel injection vs carbs.
    go to
    www.sv650.org
    and read everything on it, then you won't need to ask so many stupid
    questions.
    Ginge, Jan 27, 2004
  5. curium
    Lovely. That should do nicely.
    Pip, Jan 27, 2004
  6. curium
    dwb Guest
    <02 - carb.
    dwb, Jan 27, 2004
  7. curium
    Kiran Guest
    and.....
    Kiran, Jan 27, 2004
  8. curium
    Ginge Guest
    .......then?
    Ginge, Jan 27, 2004
  9. curium
    Ginge said...
    There's no "and then?"
    Lozzo, Jan 27, 2004
  10. Lozzo wrote
    Not even matter transporting straight into the cylinders?
    steve auvache, Jan 27, 2004
  11. curium
    Ginge Guest
    Dude!
    Ginge, Jan 27, 2004
  12. curium
    dwb Guest
    And as far as I know, that's about it - aside from the aforementioned
    cosmetic changes.
    dwb, Jan 28, 2004
  13. curium
    Ben Guest
    Sweet!
    Ben, Jan 28, 2004
  14. curium
    Pip, Jan 28, 2004
  15. curium
    Muck, Jan 28, 2004
  16. curium
    Mark Olson Guest
    One could argue that the new frame is more than a cosmetic change,
    being that it is now made using:
    "...single precision die casting using a new high-vacuum-mould process
    that eliminates bubbles, air pockets, and porosity in large castings."
    rather than the more conventional frame on the 99-02 models.
    http://www.media.suzuki.com/svlaunch/chassis.htm
    Mark Olson, Jan 28, 2004
  17. curium
    Ginge Guest
    It's a shame it looks so shit, really.
    Ginge, Jan 28, 2004
  18. curium
    muddycat Guest
    One could also argue that the '03 SV is a completely different bike than
    the previous years. There are few (if any) interchangable parts).
    muddy
    Testing the limits of gravity since 1947.
    icq - 219328929
    muddycat, Jan 28, 2004
  19. curium
    dwb Guest
    You change the frame as part of servicing?
    Now that's thorough.
    dwb, Jan 28, 2004
  20. curium
    On Wed, 28 Jan 2004 22:04:37 +0000, Ian < (really address
    S W E E T !
    Pip, Jan 28, 2004
