Suzuki TL1000R
Discussion in 'UK Motorcycles' started by Molly, May 24, 2007.
  1. Molly
    Molly Guest
    I'm looking at one of these because I love the sound they make but I don't
    have any idea of the handling or what mods can be done to them? Is this the
    one with the rotary rear suspension?
    Any pointers?
    Molly, May 24, 2007
  2. Molly
    Ben Guest
    Na, the TL-S had the rotary damper. The R has a normal shock and the
    frame is pretty much the same as the GSXR750 of the same age.
    Ben, May 24, 2007
  3. Molly
    Some.
    Yes, they have the rotary rear damper, but apparently an improved
    version of the one use on the TLS. It actually works off a separate
    linkage to the spring. It's supposedly temperature compensated, which
    it probably needs to be as the back end gets bleeding hot in summer.
    Just don't wear thin cotton jeans! According to the manual, you're not
    supposed to adjust them hot, which strikes me as being a bit silly.
    Lots of TLRs have been converted to Maxton or Ohlins, so if you have a
    choice then go for one of those. Mine is utterly stock.
    As stock they're pretty stable. In fact, I find mine too stable; it
    takes a relatively heavy lean on the bars to turn them (possibly
    Suzuki were scared by the infamy that the TLS received, who knows?). I
    fitted D207RRs because the profile was rumoured to be sharper and
    sharpen up the steering. Hard on the power on bumpy roads the bars
    will occasionally, if I'm careless, give a sudden wide flap but that
    may be down to me generally using a lighter steering damper - the
    stock one is quite stiff. I've also lowered the yokes a few mm and
    wound up the rear preload quite high. Probably a better rear shock
    would help but otherwise I personally don't have a problem with the
    suspension.
    It's very nice to ride on sweeping curves at speed. The chassis seems
    to wake up, otherwise it feels kind of dead, somehow. Hanging off a
    bit on slower corners does seem to help but that could just be me.
    This might explain why I hate riding mine in the wet: it just feels
    ponderous and remote, somehow. In contrast my Aprilia (which wears
    D208RRs) is, metaphorically, shouting and waving its arms and gabbling
    in Italian, yet still feels pretty secure. The Aprilia feels lighter
    and as though I could dominate it physically whereas the Suzuki makes
    me feel more of a passenger.
    They're quite heavy, and feel it when wheeling around the garage.
    Physically they're quite big as sprotsbikes go.
    Power is delivered much like a rather torquey four, according to a
    dyno graph I saw on the net (compared with a ZX-9R). Certainly mine
    pulls OK below 7K but you want to be above this for any serious grunt.
    At this point it simply pulls harder the faster you go.
    They have the awful Nissin six-potters at the front, though they are
    at least nice and progressive, and the standard Suzuki corrosion-prone
    underslung Nissin at the rear. Front's a tad spongy but massively
    improved since I fitted braided hoses.
    I do really like mine, I think it looks lovely and am still undecided
    as to whether to keep it. They're different and kind of the underdog
    and that appeals to me. Trouble is, I wouldn't use it on the track;
    it's too old and too heavy and I've spent too long tarting up the
    cosmetics, so I would have to keep something else for that.
    Pip Luscher, May 24, 2007
  4. Molly
    Pip Luscher says...
    No they don't, they have Tokicos, which are shite. Nissin 6 potters are
    fucking awesome, you can find them on some Daytona 1200s.
    Lozzo
    Suzuki SV650 K3
    Suzuki GSX-R750L
    Yamaha 250 Flat-tracker
    I ride way too fast to worry about cholestorol.
    Lozzo, May 24, 2007
  5. Molly
    <checks>
    You're dead right.
    Me and names. Sometimes I forget that my own name is Brian.
  6. Molly
    Molly Guest
    He usually is.
    Molly, May 24, 2007
  7. Molly
    muddy cat Guest
    Get an SV-1000 and put Yoshimura RS-3 race cans on it.
    muddy cat, May 25, 2007
  8. Molly
    Molly Guest
    Fair point but I've been offered a TL.
    Molly, May 25, 2007
  9. Molly
    muddy cat Guest
    Free?
