Suzuki RM125
Discussion in 'Motorbike Technical Discussion' started by KEITH BAUGHMAN, Nov 3, 2003.
  1. I have a 1994 Suzuki RM125 that runs well in the mid and high end, but
    terrible on the low. Idle is fine, but even on a level start you need to
    rev up the engine to get a clean start. On any type of incline I need to
    work the engine hard to get going. I've played with the jet needle and have
    adjusted it to the bottom position which has made it run better, but only in
    the mid and high end. The jet needle looks to be marred to the naked eye.
    I don't know if it is not seating proper and allowing a rich mixture or if
    I'm off base. I've pulled the carb off and ensured all ports are open and
    the float is adjusted. I've also checked the exhaust for restrictions. Any
    thoughts???
