Hi, I don't have a manual for this bike yet, so these questions may be easy. I have a 1980 JR50 that I'm trying to get running for my kids. First Problem: If kick starting hard, the clutch slips thus the crank does not turn. I have adjusted the clutch by turning the adjustment under the small clutch cover until it starts to resist, then backed off by 1/4 turn; read this procedure on the internet. Second Problem: The cylinder fills up with oil from the oil pump PDQ. Is there an adjustment for this, or are the parts that need to be replaced to fix this. I can mix the gas, but would prefer not to. Also, there is a small screw on top of the clutch side cover that has a rubber seal; is this an adjustment for the oil pump flow rate? This screw is currently completely screwed in and tight. A manual sure would help me; is there a PDF of one on line anywhere? Thanks for any help.
