Suzuki GSX-R 600 K4 Iridium Spark Plugs
Discussion in 'Motorbike Technical Discussion' started by Gixxerman, Apr 20, 2007.
  1. Gixxerman
    Gixxerman Guest
    Hi,
    I've heard and see, some motorcycles have Iridium Spark Plugs, and
    they last longer than the normal ones i use in my GSX_R600 K4, can i
    start using then also on my bike.
    The recommend plugs last for 12000 km's, how many km's or miles the
    iridium will last.
    thanks
    Jaime
    Portugal
  2. Gixxerman
    Albrecht Guest
    Google is your friend, Jaime.
    http://www.densoiridium.com/faq.php
    "DENSO Iridium Power plugs, with their .4mm center electrode, have
    been developed for performance applications. Because gradual wear will
    'round-off' firing points over time, the concentrated firing power and
    voltage requirement benefits will be reduced. For this reason, DENSO
    advises replacement after 30,000 miles."
    That's 48,000 km between spark plug changes.
    But, consider the cost of iridium spark plugs compared to standard
    spark plugs. A set of iridium spark plugs will cost me
    four times what a set of standard spark plugs will cost, but will only
    last 2.5 times as long. I change my standard spark plugs every 8,000
    miles (12800 km).
    Consider the valve adjustment interval. Some Honda and Suzuki
    motorcycles require the valves to be checked at 16,000 miles (25,600
    km) and some Yamaha motorcycles recommend checking the valves at
    26,000 miles (42,000 km).
    So, if I need to remove the fairing, gas tank and airbox at regular
    intervals to check the valves, why not install the cheaper standard
    spark plugs while the valves are being checked?
    http://www.babcox.com/editorial/cm/cm120032.htm
    "The main reason for using platinum electrodes is to minimize
    electrode wear. Every time a plug fires, a tiny amount of metal is
    vaporized and lost from the surface of both electrodes. The center
    electrode typically suffers the most wear because it runs hotter than
    the side electrode."
    "As the electrodes wear, the air gap across which the spark must jump
    becomes wider and wider. The gap on a standard spark plug grows about
    0.00063m. to 0.000126 in. for every 1,000 miles of normal driving. And
    the wider the gap, the greater the voltage needed to jump the gap. On
    standard plugs, the firing voltage requirements creep up about 500
    volts for every 10,000 to 15,000 miles of driving. Eventually, the
    plug may need more volts to fire than the coil can produce, causing
    the plug to misfire."
    "Using platinum almost eliminates electrode wear. Platinum is
    expensive, but it can double or even triple a spark plug's normal
    service life - from 30,000 to 45,000 miles for a standard plug up to
    60,000 to 100,000 miles or more with platinum. Most aftermarket plug
    suppliers do not make specific mileage claims for their platinum
    plugs, but say to follow the OEM replacement intervals - which in most
    cases is 100,000 miles for platinum plugs."
    "Denso and NGK have both introduced new premium plugs with iridium
    alloy electrodes. NGK says iridium is even better than platinum in
    terms of corrosion, and resistance and ignition performance."
    Albrecht, Apr 20, 2007
  3. Gixxerman
    James Clark Guest
    Are you sure it's not because of the polarity of the coil?
    Single platinum tipped plugs aren't recommended for engines using double-ended coils.
    Harley only offers double and triple tipped plugs to address this issue.
    James Clark, Apr 20, 2007
  4. Gixxerman
    Albrecht Guest
    You may not have noticed that the statement was a quote from
    "But the Barrister, weary of proving in vain
    That the Beaver's lace-making was wrong
    Fell asleep, and in dreams saw the creature quite plain
    That his fancy had dwelt on so long."
    ----Lewis Carroll http://rpo.library.utoronto.ca/poem/438.html
    Albrecht, Apr 21, 2007
  5. Gixxerman
    oldgeezer Guest
    James Clark schreef:
    I've been in the DC-welding area for some years and did lab work
    on electrodes. Measuring temperatures like I did cannot be compared
    to whatever happens inside a combustion chamber and how tip and
    side electrode of a spark plug can get rid of the heat, but:
    When you have two identical electrodes, the minus gets hotter than
    the plus, and the plus wears faster.
    Reason is that the negative electons are lighter than the
    positive particles (atoms with a few missing electrons).
    Wear is easy to understand. The positive electrode spits out
    atoms+electrons. The negative spits out electrons only.
    And the positive electrode thus wears faster.
    Temperature difference comes because the negative
    electrode is bombarded with (heavy) atoms, and
    the positive electrode is bombarded with light electrons.
    The kinetic impact energy of the atoms heats the
    negative electrode more than the electron bombardment
    does to the positive electrode.
    Like I said, the difference in temperature cannot be
    compared to what happens in the cilinder.
    But the positive electrode will wear out faster anyway.
    I don't know why Platinum lasts longer. It really does.
    We used Wolfram (Tungsten) for electrodes. It may have to do with
    the internal bonding force between atoms, but this is a guess.
    And further:
    Did I ever buy Platinum spark plugs?
    No. Not worth the price.
    Rob.
    oldgeezer, Apr 21, 2007
  6. Gixxerman
    Albrecht Guest
    "Q. What makes Iridium better?
    A. Until recently, platinum was considered the best material to use on
    the top of an electrode because of its durability. However, Iridium is
    6 times harder, 8 times stronger, and has a melting point 1200 degrees
    higher than platinum. Put that into a harsh environment such as an
    engine piston chamber, and you have a spark plug that can resist wear
    much better than platinum. Additionally, the DENSO Iridium Power alloy
    is so durable; it allowed our engineers to produce the world's
    smallest center electrode (.4mm) which reduces the voltage
    requirements, concentrating its sparking power. Also, its smaller
    size, combined with the tapered U-Groove ground electrode, allows more
    room for the flame kernel to develop and produce a more efficient
    combustion."
    http://www.theodoregray.com/PeriodicTable/Elements/SparkPlugs/index.html
    Elements in spark plugs
    http://en.wikipedia.org/wiki/Spark_plug
    "At one time it was common to remove the spark plugs, clean deposits
    off the ends either manually or with specialized sandblasting
    equipment and file the end of the electrode to restore the sharp
    edges, but this practice has become less frequent as spark plugs are
    now merely replaced, at much longer intervals. The development of
    precious metal high temperature electrodes (using metals such as
    yttrium, iridium, platinum, tungsten, or palladium, as well as the
    relatively prosaic silver or gold) allows the use of a smaller center
    wire, which has sharper edges but will not melt or corrode away. The
    smaller electrode also absorbs less heat from the spark and initial
    flame energy. At one point, Firestone marketed plugs with polonium in
    the tip, under the questionable theory that the radioactivity would
    ionize the air in the gap, easing spark formation. (See external link
    below)"
    I tried about two sets of Champion Gold Palladium plugs in the
    mid-1970's. Their claim to fame was that they ran too hot to foul with
    the rather low voltage available from the coils. The part$ guy who
    touted them to me said that I shouldn't worry about the fact that the
    center
    electrode would actually *melt* into a round blob...
    "The Witnesses proved, without error or flaw,
    "That the sty was deserted when found:
    "And the Judge kept explaining the state of the law
    "In a soft under-current of sound.
    "The indictment had never been clearly expressed,
    "And it seemed that the Snark had begun,
    "And had spoken three hours, before any one guessed
    "What the pig was supposed to have done."---Lewis Carroll, "The
    Hunting of the Snark"
  7. Gixxerman
    OH- Guest
    On a spark plug, we've got nothing like two identical electrodes.
    The center electrode is fairly long and how well it's connected
    to the heat sink (cylinder head) is one of the factors that determines
    the plug heat number.
    The side electrode is short, relatively thick and thus well connected
    to the heat sink. OTOH it is very exposed.
    AFAIK, transport of metal between the plug electrodes is the
    last thing we want to see.
    If I may make a guess, I would say that the heat of combustion
    totally dominates over any electrically caused heating.
    OH-, Apr 21, 2007
  8. Gixxerman
    oldgeezer Guest
    OH- schreef:
    I said *When*, I talked about lab-conditions.
    And yes. We could make a fortune if we invented one and marketed it
    right: 'More power, longer lifetime. less fuel consumption, good for
    the environment, girls love it'. I'd fall for the last reason.
    It is inside insulator material, but I know what you mean. BTW, an
    electrical
    insulator usually also is a good thermal insulator.
    Yes, there is no formula to calculate which one is the hottest.
    Correct. But we see it. If it wasn't the case you'd never have to
    install new plugs.
    No guess needed. It does.
    Let me retry to write what I wanted to say:
    Heat is movement of atoms. The hotter, the faster they
    move, or- in solid material anyway- vibrate.
    Many atoms on the surface of hot material will jump off of the
    surface, but most will be pulled back onto the surface
    because of the force that holds atoms together.
    But some will escape (if temp is high enough).
    Water already does that at room temperature. We
    call that evaporation. But note that evaporation does
    not mean that the metal must be in a liquid phase.
    If there is a negative electrode close by (an
    electric field), then there will escape more
    atoms from the positive electrode, because
    the negative electrode pulls on them.
    So *at equal temperature(!)* a positive electrode
    will loose more atoms over time than a negative
    electrode.
    I don't know wether center or side is the hottest,
    but the fact that usually the center is cladded with
    expensive material makes me think that the center
    is the hottest, or that the electric field helps the
    center to loose atoms most, or maybe both things
    together is the reason for center cladding.
    Rob.
    oldgeezer, Apr 22, 2007
