Suzuki GS400 Starter relay
Discussion in 'Motorbike Technical Discussion' started by Gray, Nov 25, 2005.
  1. Gray
    Gray Guest
    MY Suzuki GS400 has developed a problem with the starter relay. When I
    start the bike the terminals on the relay begin to burn! Why is this?
    Relay clicks but does not turn starter motor! At a loss, please help!
    Gray
    Gray, Nov 25, 2005
  2. Very likely the terminals are not making good contact due to corrosion or just
    being loose. First, disconnect your battery negative lead. Then remove and clean
    the relay terminals and the relay. Connect the battery back up and try it again.
    James B. Davis, Nov 26, 2005
  3. <Nods in agreement>
    The Older Gentleman, Nov 26, 2005
  4. Gray
    CK Guest
    Are the large cables the ones that are burning or the small wires?
    The big cables burning indicate a possible shorted out starter or a
    jammed starter clutch. Remove the alternator cover and take the small
    reduction gear off the shaft and see if the starter then turns freely
    when you push the button. The larger idler gear will only turn freely
    in the counterclockwise direction, it is supposed to engage the
    crankshaft in the normal clockwise direction. Broken bolts that are
    supposed to secure the starter clutch to the back of the alternator can
    jam the starter clutch. Remove the starter and see if you can turn it
    freely by hand.
    The smaller wires burning might indicate a shorted starter solenoid
    coil
    CK, Nov 26, 2005
