Hi I'm trying to remove the flywheel on my 1992 Suzuki GS125. I have a 27mm "universal flywheel puller for the majority of japanese motorbikes" however..... I have removed the nut on the end of the crank but there is still a black metal cone shaped thing with a thread on the oustide of it and flats on the side so it can be gripped with an open spanner that seems to bolt into the flywheel. The flywheel puller seems to be the same size as the black metal cone. I have tried removing this by turning it both ways but it wont budge. Should my flywheel puller bolt onto the outside of this, or should I be able to remove it and then screw the puller into the flywheel itself and that will lever it off? The majority of flywheel puller i've seen haver an external thread, is it possible the one I have need an internal thread. Tghanks for your help, it the bike I passed my test on an I feel it deserves to be back on the road for someone else to do their test on!
