Suzuki gear indicator lights
Discussion in 'UK Motorcycles' started by The Older Gentleman, Apr 17, 2010.
  1. On the GN250. Only 3 and 4 were working. OK, so I can count to five, but
    I thought I'd have a go at fixing the other three.
    There's a separate tiny bulb for each indicator light. Suzuki want more
    than £4 for each one (which includes the rubber push-in mount, although
    the bulbs themselves can be separated).
    I hied me to Maplins with a dead bulb as a pattern. WQ13 0177 is a
    direct replacement, for just over a quid each. Page 471 of the current
    catalogue, if anyone's interested.
    No idea what other Suzukis have illuminated gear indicator panels these
    days, but I wouldn't be surprised if they use the same bulbs.
  2. The Older Gentleman
    the V reg GS125ES I passed my test on had one.
    wessie, Apr 17, 2010
  3. The Spagthorpe Metro Hexual six-speeder Gentleman's City Motorcycle had
    a crank, pivot and rod arrangement which transferred the gearlever
    movement to a click-stop moving slit on a quadrant mounted above the
    carbide headlamp, thus providing an instant readout of gear placement at
    night.
    A slight drawback was the tendency for it to change gear whilst
    cornering, sometimes more than one, as the linkage wore and got snagged
    in the headstock.
    Grimly Curmudgeon, Apr 17, 2010
  4. The Older Gentleman
    Dave Emerson Guest
    Didn't they do an after-market cable conversion kit to solve this problem?
    Dave Emerson, Apr 17, 2010
  5. The Older Gentleman
    Jérémy Guest
    When my gf's Sportster's rear/brake bulb went all broken in Cortina, after
    a morning's Internet research and phoning around Chrysler dealers (ffs) we
    ended up going to the nearest HD place, which was in Bolzano. It was,
    without doubt, one of the world's best days out on a motorbike, but for a
    bulb? And they charged us for the Coke in the showroom bar. Assholes.
    Jérémy, Apr 17, 2010
  6. Using the patented Mavis Beacon "Hunt&Peck" Technique, Dave Emerson
    Of course not, you silly man.
    The Spagthorpe solution was absolutely in keeping with the fine
    engineering tradition of that august[1] brand.
    They simply fitted an interlock cam which monitored the wear in the
    linkage. Once it had exceeded a defined limit (which could be adjusted
    to suit the owner's preference), an outrigger was automatically deployed
    to limit lean-angle. Thus, the unwanted gear-change was completely
    eliminated, and normal function was restored.
    [1] <nods> to Krusty
    Wicked Uncle Nigel, Apr 17, 2010
