Suzuki G250 carb
Discussion in 'Motorbike Technical Discussion' started by The Older Gentleman, Jan 31, 2010.
  1. All the symptoms of pilot jet trouble: started instantly on the choke,
    was a real bugger until it had got nice and hot, erratic tickover, would
    only tick over when hot, and then if you sort of nursed the revs gently
    and let it settle down before removing your hand from the twistgrip.
    So today: carb off bike, all jets, float, needle valve, etc removed,
    loads of carb cleaner and high pressure air blasted everywhere. There
    did seem to be a bit more light showing at the end of the pilot jet
    after the treatment. Everything inside the carb was as clean as a
    whistle, mind. No gunge anywhere.
    And then, the killer punch: checking the pilot screw setting. Yup,
    someone had wound it out to at least three turns. Set it to a turn and
    three-quarters and behold! Nice starting, lovely even tickover, sweet
    pick-up from idle.
    All done on the kitchen table because the garage is freezing cold. It's
    lovely when it all goes back together tna dhte thing just works as it
    should do.
  2. The Older Gentleman
    Gael Guest
    So which would you prefer, sweetie, a pat on the head or a pat on the
    bum?
    Gael, Jan 31, 2010
  3. Quote From KrustyUS, posting in another thread earlier.
    "You just cross-posted *again*!
    You're dumber than dogshit, aren't you?"
  4. The Older Gentleman
    Gael Guest
    Your point being...?
    Gael, Jan 31, 2010
  5. The Older Gentleman
    Dave H. Guest
    Either way, sleep under a cow?
    Dave H.
    Dave H., Feb 3, 2010
  6. The Older Gentleman
    S'mee Guest
    Naw, she snores, now the pig? Ah, the pig...she might eat a bit much
    and she's bit of a mess at times but at least she doesn't snore.
    S'mee, Feb 3, 2010
  7. The Older Gentleman
    Hank Guest
    Gentlemen, that was refreshingly brief!
    Maybe Krusty got hit by a bus?
    Hank, Feb 8, 2010
  8. The Older Gentleman
    ` Guest
    It seems that "The Older Gentleman" was able to get his panties
    unknotted quickly, so he didn't continue this self-serving and
    irrelevant thread for 90~100 posts.
    But it can be resurrected...
    What did Krusty ever do to you? He stays in ukrm and doesn't bother
    anybody...
    `, Feb 8, 2010
  9. The Older Gentleman
    S'mee Guest
    gee shit head considering YOU are Krusty Kritter the zoophile,
    chickenhawk and the singularly most unknowledgeable person about
    motorcycles on the planet...your bit of disingenious bullshit is
    unsurprising.
    Oh and ESADYFFF
    S'mee, Feb 8, 2010
  10. The Older Gentleman
    ` Guest
    The world knows it by now.
    `, Feb 8, 2010
  11. The Older Gentleman
    S'mee Guest
    Thankyou for the honesty adn the blatant fabrication of my
    post...further proving my point.
    S'mee, Feb 8, 2010
