Suzuki Bandit question
Discussion in 'UK Motorcycles' started by RogerTBrick, Oct 21, 2003.
  1. RogerTBrick
    RogerTBrick Guest
    I have a UK spec [or so I believe it to be] '00 GSF600S.
    A wee conversation on one of the Bandit lists has raised a question in
    my mind - does this have carb heaters fitted as standard? Helpfully
    this is exactly the kind of question the Suzuki site doesn't aswer.
    Typical!
    If heaters are fitted, what should I see? Or is there no visible,
    external component?
    Cheers!
    HairyMuppet.
  2. RogerTBrick
    Gizzmo Guest
    There are 4 connecting wires under the carbs which feed the heaters.
    These are the easiest items to spot.
    If these wires actually plug into the bottom of the carbs then you have the
    heaters installed.
    Brian
    Gizzmo, Oct 21, 2003
  3. RogerTBrick
    Alan.T.Gower Guest
    If you find them and don't want them, I'll have them.
    Alan.T.Gower, Oct 21, 2003
  4. RogerTBrick
    jsp Guest
    Always asking for Bandit bits.
    You don't want a Rentec sports rack, do you?
    John
    SV650
    Black it is
    and naked
    jsp, Oct 21, 2003
  5. In uk.rec.motorcycles, Alan.T.Gower said:
    If you still want them you can have mine. It appears my bandit needs a
    new engine to be repaired economically and a new engine's not my idea of
    economical.
    Especially at the moment.
    Whinging Courier, Oct 21, 2003
  6. RogerTBrick
    Alan.T.Gower Guest
    I'm trying to teach my son how to keep a bike on the road without
    spending a fortune. Unfortunately, he keeps crashing it.
    Alan.T.Gower, Oct 22, 2003
  7. RogerTBrick
    RogerTBrick Guest
    Ta Brian - seems I do have carb heaters fitted.
    Alan - keep you hands off my bits. :p
    RtB.
    RogerTBrick, Oct 22, 2003
  8. RogerTBrick
    And you keep fixing it for him. What kind of example is that?
    Ace, Oct 22, 2003
  9. RogerTBrick
    Ginge Guest
    Seems the kid has learnt all he needs.
    Ginge, Oct 22, 2003
  10. RogerTBrick
    Round here, we call it "Doing a Rope".
    Pip, Oct 22, 2003
  11. RogerTBrick
    heh. QUite.
    Champ, Oct 22, 2003
