Suzuki 2006 C50T Electrical
Discussion in 'Motorbike Technical Discussion' started by Brillo, Jul 5, 2006.
  1. Brillo
    Brillo Guest
    I'm looking for a wiring diagram so I can install an alarm system. I
    need to know how the ignition switch is wired. If it cuts power or
    grounds the ignition like a magneto would be grounded to shut off the
    engine. And finally is the ignition system a single fire or dual fire
    ignition?
    Can anyone help out please?
    Brillo, Jul 5, 2006
  2. Brillo
    FB Guest
    Look in the back of your owners manual. The red wire goes from the
    battery to the main fuse to the ignition switch, the orange wire comes
    back to the fuse box to power everything that is supposed to be powered
    when the key is on.
    So you need to power your alarm from the red wire or run a wire with an
    inline fuse directly off the battery positive terminal and you need to
    get the arming/disarming signal from the orange wire.
    Don't power your alarm from a wire near the handlebars that a thief
    could easily cut.
    Battery and coil ignition systems on street bikes use the ignition
    switch to supply power to the coils.
    Very few street motorcycles have magnetos, but it's common with dirt
    bikes. The only street bike I ever owned that had a magneto was using a
    part from a production roadracer, it didn't come stock with a mag.
    I dunno. Why don't you just remove your spark plugs and reconnect the
    spark plug caps and ground the plugs and turn the key on and watch to
    see what happens when you thumb the starter button.
    Both sparks at once = dual fire. Alternating sparks = single fire.
    If your Screwzuki has carburetors, it doesn't need a single fire
    system.
    If it has fuel injection it will have a crank angle sensor on the side
    of the engine or on the end of one camshaft that tells the ECU when to
    squirt gas to which cylinder.
    The reason Harley went from dual fire to single fire was they put fuel
    injection on the Road King model. The older dual fire system triggered
    two sparks at once, using a single sensor to send a signal to the
    ignitor unit and it didn't matter that one spark fired while the
    exhaust valve was still open.
    But, with fuel injection, they needed a different, single fire system
    to keep the fuel injector from squirting a shot of gas to the cylinder
    that was on the exhaust stroke.
    An advantage to using a single fire system is that it eliminates the
    V-twin rumble in the exhaust. That comes from burning excess fuel in
    the exhaust pipe when the
    waste spark fires.
    FB, Jul 5, 2006
