suzuki 125 intruder not starting
Discussion in 'UK Motorcycles' started by Rayrosher, Oct 7, 2004.
  1. Rayrosher
    Rayrosher Guest
    Hi all
    I've just got a Suzuki 125 intruder 2000 model 4000 miles on the clock
    been laid up in the garage for the past 2 years
    runs like a clock, the only thing is, i'm having to bump start the
    bike, i've read somewere that it as some kind of anti start system, ie
    if it's in gear, kick stand down etc just wondering what to check to
    fix the problem,
  2. X-Complaints-To:
    Abuse report sent.
    Whinging Courier, Oct 7, 2004
  3. Whinging Courier wrote
    Why?
    steve auvache, Oct 7, 2004
  4. Rayrosher
    Mark Olson Guest
    "Whoosh"
    Mark Olson, Oct 7, 2004
  5. Mark Olson wrote
    Perzackerly.
  6. Rayrosher
    Mark Olson Guest
    I'm afraid I just got it.
  7. Mark Olson wrote
    Really? Too fucking subtle for me.
  8. Rayrosher
    Mark Olson Guest
    Wheels within wheels, it's a mind game of dizzying complexity.
    If a haughty fellow was inclined to decide what was an appropriate
    obligation to be laid at the feet of a humble biker supplicant toward
    the HBS's unfortunately neglected steed, said haughty fellow might go
    so far as to cry foul over the blackhearted deed of omission that the
    benighted fellow had unknowingly committed.
    Isn't whiskey wonderful
  9. Rayrosher yik-yakked:
    On my VS, you need to have the clutch pulled in whilst you're cranking
    the start button. No idea if yours is the same, or if that would even
    cause this, but you might want to try it.
    Dave Jennings, Oct 7, 2004
  10. Mark Olson yik-yakked:
    Fucking right it is. I have no idea what you're on about, which is par
    for the course for me.
  11. Rayrosher
    Petel Guest
    If it`s got a starter interlock system it`s got two breakers/switches one
    located under the clutch lever the other at the top of the sidestand.
    Both have two wires going to them, these break the starter circuit when the
    lever is out or the sidestand is down.
    To test them unplug them from their positions and using a piece of wire
    bridge the gap ie. make the circuit complete.
    If this works the switches are faulty, replace them or simply cut the two
    wires and join them together making the circuit.
    Petel .
    02 M2 Buell.
    C90-ZZR.
    Piaggio/Gilera 125 Red Dwarf Sprinter
    http://homepage.ntlworld.com/peteh1/website/index.html
    Petel, Oct 7, 2004
  12. Rayrosher
    Rayrosher Guest
    Thanks Dave tried all of that!
    just wondered if theirs some switches or relay that could be faulty or
    need freed off, with it being laid up for so long,
    havent had a suzuki before so not sure were to start,
  13. Rayrosher
    dwb Guest
    That's just daft...
    dwb, Oct 7, 2004
  14. Rayrosher
    Petel Guest
    See my post.
    Petel .
    02 M2 Buell.
    C90-ZZR.
    Petel, Oct 7, 2004
  15. Rayrosher
    Angle grinder. :)
    Muck, Oct 7, 2004
