Sump plug
Discussion in 'UK Motorcycles' started by Gavin, Apr 19, 2010.
  1. Gavin
    Gavin Guest
    Just done the oil and filter on the Suzuki, the book says the sump plug
    should be at 23 newton meters, that felt like not much at all on the
    torque wrench, i assume thats its a low pressue enviroment, and as the
    thread is very fine, its tighter than it felt?
    Gavin.
    GSXR600K1
    Twitter: http://twitter.com/gavin_wilby
    Blog: http://www.stoof.co.uk
    Gavin, Apr 19, 2010
  2. Gavin
    Correct. Stick to the manufacturers torque settings, and remember they
    are for a dry thread.
    Lozzo, Apr 19, 2010
  3. Gavin
    Gavin Guest
    Well, it was dry(ish) as dry as I could get it with a rag.
    I didnt degrease it though, if thats what you mean...
    Gavin.
    GSXR600K1
    Gavin, Apr 19, 2010
  4. Gavin
    zymurgy Guest
    It's oily on the threads, so it will have gone tighter than an unoiled
    thread.
    I tend to do it by feel, hand tight then a small nip [1]. It also
    depends whether you' re using a new or reusing an old washer, the new
    one will be annealed, so will do up more, an old one will be work
    hardened.
    If you're not happy doing it by feel, you'll just have to trust the
    torque setting.
    Paul.
    [1] I also only use 3/8" drive socketry, or a spanner which means it's
    more difficult to put too much torque through the plug.
    zymurgy, Apr 19, 2010
  5. Gavin
    Gavin Guest
    Im OK doing it myself, it was just a confirming question really.
    How many of us though tighten to the torque setting and then give it a
    little bit more?
    It might just be that the length of the wrench makes it feel like your
    putting next to naff all on the nut itself. Although stripping the sump
    thread would not fill me with joy.
    Gavin.
    GSXR600K1
    Gavin, Apr 19, 2010
  6. Gavin
    YTC#1 Guest
    Don't over tighten, its a pain in the arse when you over tighten and it
    goes all loose :-(
    YTC#1, Apr 19, 2010
  7. Gavin
    crn Guest
    The threads in the alloy case are very easy to strip if overtorqued.
    There is almost always a special alloy or fibre washer or maybe an O ring.
    ALWAYS use a new one.
    crn, Apr 19, 2010
  8. Gavin
    I've got a decent torque wrench at home but the only time I'd use it
    is if I was tightening something like a cylinder head that needed
    sequential tightening or if the bolts were designed to stretch once
    and when you needed to undo them you replaced them.
    Always remember that spanners are different lengths for a reason and
    only a **** uses a breaker bar when tightening something.
    Andy Bonwick, Apr 19, 2010
  9. Gavin
    Gavin Guest
    Actually the book says that you dont have to!
    Gavin.
    GSXR600K1
    Gavin, Apr 19, 2010
  10. Gavin
    35 years of riding motorbikes and servicing them myself has never seen
    me change a sump plug washer.
    You're still talking shit for a hobby.
  11. Gavin
    Gavin Guest
    Just checked and both the offical manual and the Haynes say its not
    required to change it.
    Gavin.
    GSXR600K1
    Gavin, Apr 19, 2010
  12. Gavin
    Gyp Guest
    So is it a flat washer or one that deforms?
    Gyp, Apr 19, 2010
  13. Gavin
    Gavin Guest
    Gavin, Apr 19, 2010
  14. Gavin
    AOL, on cars or bikes. Never had a leak.
    Krusty, Apr 19, 2010
  15. Gavin
    Triumph are the only manufacturer I know of who supply deformable sump
    plug washers, and a new one is usually in the box with the oil filter.
    Lozzo, Apr 19, 2010
  16. Ditto. I have been known to anneal the odd one, or replace it if
    knackered though.
    Grimly Curmudgeon, Apr 20, 2010
  17. Gavin
    If in doubt he could always 'wire it ;o)
    Hog, Apr 20, 2010
  18. Gavin
    I hadn't either, until the first oil change I did on the Vectra. It
    started marking its place immediately - just a drip a day, but a bit
    annoying, having got used to oiltight vehicles. Next time I bought a
    filter, I asked for a washer and my friendly factor threw three in the
    filter box for me. Bonus.
    Of course, I couldn't find then last week when it was that time again,
    and as they're just common flat copper washers, I got the torch out and
    annealed it. Still drip-free.
    Bit difficult lockwiring a washer, isn't it?
    Pip, Apr 20, 2010
  19. Gavin
    He didn't mention overtightening a washer though, did he.
    IIRC OE Beemer service kits had soft ally washers on some of the plugs which
    were best changed.
    Hog, Apr 20, 2010
  20. Gavin
    crn Guest
    The deformable ones should always be changed, and that includes all
    fibre washers. I was taught to always fit a new one to be sure of
    getting it right, they only cost a few pence FFS.
    Better safe than sorry.
    crn, Apr 20, 2010
