Suggestions on rear shock replacement for a BMW K1200RS
Discussion in 'Australian Motorcycles' started by David, Nov 11, 2005.
  1. David
    David Guest
    The rear shock on my 98 model K1200RS is stuffed, so that it now
    bottoms-out over bumps one-up, even with preload on max. Since I plan to
    do the Snowy Ride in a few weeks, two-up with extra gear, I reckon I
    need to replace the shock urgently.
    The local BMW shop offers:
    1. the same shock for approx $860, ex Germany,
    2. the version used on the K1200GT, which has the addition of a remote
    preload adjustment for $900, ex melb, or
    3. an Ohlins replacement for $1600.
    Given I need to get this done before the Snowy Ride (26th Nov), and
    price is importatn, #2 is the only real option.
    While I expect the BMW OEM shocks are probably great, I wonder if there
    are any other after-market shocks avalable in Australia at a similar
    price which offer more features.
    I have done a web search with no success.
    Anu suggestions please?
    David
    David, Nov 11, 2005
  2. David
    Boxer Guest
    Shop around for a better price on the Ohlins, you should be able to pick one
    up for $1,350 or so.
    I have Ohlins on my K1100LT, K100RT with HRD Sidecar and my R100GSPD, and
    would highly recommend them being a much better option than a stock unit.,
    don't waste you time on inferior products.
    Boxer
    Boxer, Nov 11, 2005
  3. David
    IK Guest
    If you're in Sydney, call a suspension place like Terry Hay's Shock
    Treatment, Frank Pons' Biketek or Dave Cullen's Radar's Shock Service
    and ask how much to have your shock overhauled... new oil and internals,
    plus, if you need it, new spring, all for a lot less than any of the
    options you list.
    IK, Nov 11, 2005
  4. David
    sharkey Guest
    Sure, sure, expect away. They're garbage.
    Either pony up for a top-of-the-line replacement, or buy a cheaper
    replacement for less than the stocker: it'll most likely work
    better anyway.
    -----sharks ('93 R100GS, Bitubo CZE shockie, ripper)
    sharkey, Nov 11, 2005
  5. David
    David Guest
    I didn't think it was feasible to rebuild the original BMW shock.
    Since cost is an issue that would be a good option.
    I'll make some calls Mon AM.
    Thanks
    David
    David, Nov 11, 2005
  6. David
    David Guest
    I managed to stretch the domestic financial controller to $900 for the
    BMW shock. I hate to think what I would have to do to push that another
    $450 :)
    Realisticly, around $900 is my limit currently. In a few years when kids
    have finished high school, then we'll see ....
    Thanks for the suggestion
    David
    David, Nov 11, 2005
  7. David
    Boxer Guest
    A rebuild could get you out of trouble for a year or two for about half the
    price of a new OEM shock.
    Boxer
    Boxer, Nov 11, 2005
  8. David
    IK Guest
    A lot of these guys will pick up the phone on Saturday mornings.
    Terry Hay, for instance, works out of a shed on his property out the
    back of Penrith.
    Why only a year or two? When they rebuild a stock shock, they typically
    use higher-spec components like seals, needles and valves than OE.
    IK, Nov 11, 2005
  9. David
    Boxer Guest
    My "Guess" of a year or two was based on his useage.
    Boxer
    Boxer, Nov 11, 2005
  10. David
    David Guest
    Usage would be about 10K kms per annum.
    David
    David, Nov 11, 2005
  11. David
    Boxer Guest
    Mailnty related to weight of the load and weight of the bike and kilometres
    travelled and the fact that the original shocks were not that good.
    My Ohlins have a renote oil resovour that reduces fade by allowing greater
    oil volume and better cooling.
    Boxer
    Boxer, Nov 11, 2005
  12. David
    FuTAnT Guest
    Well, mine is still fine. Has it rebuilt at 6k, now has 24k on it, still
    works a treat. Dave Cullen did the work, but he is now in Brisbane working
    for the Paul Feeney Group. Will still do suspension work however it's a bit
    hard for you to get the bike to him. The other two options in Sydney, well
    ... who knows, both pluses and minuses. Still, get it reworked, should be
    fine. For $900 you could get the front AND the rear reworked and you'll be
    carving up the twisties like there's no tomorrow. Do yourself a favour, do
    the front at the same time.
    FuTAnT, Nov 11, 2005
  13. I had a Koni shock on a K100, it was great...I had a lighter spring made
    though
    Since me missus and me weigh 120kg, and the original spring was for 2
    solid Germans and their luggage
    And progressive front springs are worth the addition too
    on a CBR 600 I had the original shock worked over and a remote reservoir
    added, this cost a couple of hundred back in '96, much the same and a
    lot cheaper than an aftermarket shock
    fulliautomatix, Nov 11, 2005
  14. David
    David Guest
    Apparently Dave 'Radar' Cullen has moved his business back to QLD (again?).
    Unfortunately, Terry Hays and Frank Pons are both a long way from my
    normal haunts, making the logistics very difficult.
    While I was at Castle Hill, looking for Radars, I stopped into MAW. They
    suggested trying Chivos at Granville. I have spoken with Chivos, and
    they reckon they can probably rebuild the shock, for approx $180. At
    that price it is probably worth doing both front and rear.
    Thanks for the pointers
    David
    David, Nov 14, 2005
