Suggestions on a Honda charging system
Discussion in 'Motorbike Technical Discussion' started by Ted Mittelstaedt, Jun 9, 2008.
  1. Ted Mittelstaedt
    ian field Guest
    Don't know if they sell them where you are, but there's a handy product
    called sandflex polishing blocks. Its a rubber block filled with diamond
    particles and comes in a variety of grades from very coarse to "mirror
    finish", they're not cheap but there are cheaper imitation brands which are
    predictably not as good.
    ian field, Jun 13, 2008
  2. None.
    Ted
    Ted Mittelstaedt, Jun 15, 2008
  3. Brasso.
    Ted
  4. Ted Mittelstaedt
    paul c Guest
    Thanks, one further question - did you clean the Brasso off afterwards?
    Or is the makeup of that stuff such that it doesn't matter?
    paul c, Jun 15, 2008
  5. I cleaned it off with some old gasoline I had around that had gone bad
    (from the lawnmower tank) Of course, gasoline like most petroleum
    products is an insulator, but the thin film of gas left on the ring would
    be wiped off quite quickly by the brushes.
    Brasso is likely conductive. With polishes, of course you apply them
    sparingly to the rag and use elbow grease so your not gopping it
    onto the ring to begin with, but there is no point in getting even a small
    amount of dusty grit into the mechanism later.
    The interesting thing I found was that this even happened to the
    slip rings at all. I don't know what metal the brushes were made of
    (probably copper and graphite powder and a clay binder) but their
    resistance was quite low - yet whatever was deposited on the slip
    rings had quite a high resistance, comparatively. Copper Oxide
    is normally soft and easily wiped away by the action of the brushes
    on the slip ring. I guess maybe the age of the bike had deposited such
    a thick film that it didn't matter.
    Ted
    Ted Mittelstaedt, Jun 17, 2008
