Stupid Question
Discussion in 'UK Motorcycles' started by SteveH, Jun 20, 2005.
  1. SteveH
    SteveH Guest
    In the absence of any form of paddock stand, is there any way to remove
    both wheels from my VFR at the same time?
    Obviously it has a centre stand and I also have a trolley jack, if that
    helps.
  2. remove back wheel, replace wheel spindle prop with axle stand, remove
    front wheel, replace spindle and use trolley jack to make sure it is
    held up ok
    <--ROT13 it
    Spam Trap in Header
    GS850 Trike
    For animals, the entire universe has been neatly divided into things to
    (a) mate with, (b) eat, (c) run away from, and (d) rocks.
    http://borg.no-ip.com
    ‹(•¿•)› BORG, Jun 20, 2005
  3. SteveH
    SteveH Guest
    Hmmm, how does this work for a single sided swingarm?
    Alternatively - any ideas of somewhere cheap-ish that'll do a ride-in,
    ride-out service around these parts?
  4. SteveH
    Statto Guest
    Not strictly "around these parts" for you, but ProTyre in Bristol put
    a pair of Pirelli Diablos onto the VFR for £197, RIRO.
    Statto, Jun 20, 2005
  5. SteveH
    SteveH Guest
    Worth a thought, but the rear is very marginal. Riding to Bristol could
    see it down to the canvas. Erk!
  6. SteveH
    Statto Guest
    If nothing else, you can gauge how expensive tyre places are closer to
    home. FWIW, FWR charge £179 for a pair of Diablos, so £18 for RIRO is
    money well spent.
  7. Not-so-silly response - if you've got a spare front wheel off a smaller
    bike, just shove the spindle through it and through the forks, and it'll
    hold the thing off the deck while you take the wheels to be re-tyred.
    The Older Gentleman, Jun 20, 2005
  8. SteveH wrote
    Park it more or less anywhere you like in Tilbury for 2 minutes.
    steve auvache, Jun 20, 2005
  9. Ahh ok, use the front end bit and put the axle stands under the
    footpegs then
    <--ROT13 it
    Spam Trap in Header
    GS850 Trike
  10. SteveH
    SteveH Guest
    Heh. I *could* drag the MZ out for that purpose.
    But I'm going to phone this lot tomorrow:
    http://www.mgtyres.co.uk/
  11. SteveH
    Cammo Guest
    No need to support the wheelless rear end when it's on the centre
    stand, so then just take the front off and plonk the forks down on a
    block of wood, or stick the spindle back in and rest it on your jack.
    Easy, done it loads.
    Have you tried MG tyres for a ride nowhere approach to tyre
    supply/fitting?
    Cammo, Jun 20, 2005
  12. SteveH
    Cammo Guest
    Ignore my last post then. Phone him now, it's a work from home thing,
    speak to Mark.
    Cammo, Jun 20, 2005
  13. SteveH
    SteveH Guest
    Yeah, I remembered your MG Tyres suggestion from a couple of weeks ago.
    I think they'll be getting my money, so long as they don't take the piss
    on prices.
  14. SteveH
    dwb Guest
    Turn it upside down and take the wheels off.
    dwb, Jun 20, 2005
  15. SteveH
    SteveH Guest
    Heh. Catman said exactly the same on ICQ.
  16. Loosen front and rear wheel fixings.
    Put it on the centre stand.
    take off the rear wheel.
    Jack up under the engine with suitable blocks.
    Remove front wheel.
    Don't let the cat sit on the back of the bike.
    ColonelTupperware,
    spouting bollocks on Usenet since 1997
    Usenet FAQ at
    http://www.its.caltech.edu/its/services/internetapps/news/news2.shtml
    UPCE FAQ at http://upce.org.uk/ UKRM FAQ at http://www.ukrm.net/faq/
    Colonel Tupperware, Jun 20, 2005
  17. SteveH
    OH- Guest
    Not necessary, just stick something solid under the swing arm
    after removing the rear wheel. (The bike will rest on this,
    lightly, and the center stand after the front wheel is removed)
    Trolley jack or whatever is handy. No real need to replace spindle,
    just push something (not too high, that would unload the center
    stand) under one of the fork legs.
    A smart move when doing this sort of job is to secure the center
    stand in the down position with some wire or rope. Pulling the bike
    of the stand when trying to undo/tighten a nut is damn irritating.
    DAMHIK, IJK, OK?
    OH-, Jun 20, 2005
  18. SteveH
    Salad Dodger Guest
    I had both wheels off the Wing using that arrangement last winter.
    Looked *well* dodgy, mind.
    | ___ Salad Dodger
    |_\_____/_| ..75830../..18846.../..3214./.19406
    \|^|/ ANORAK#17 IbB#4
    '^' RBR Landmarks: 24 Pts: 400 Miles: 1589
    Salad Dodger, Jun 20, 2005
  19. SteveH
    Easy. Take it to almost any bike dealer and they'll do it for you. Why
    anybody bothers taking their wheels off to save a tenner or so for the
    dealer to do it is beyond me.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Jun 20, 2005
  20. SteveH
    Bike on centre stand > remove front wheel > use trolley jack to take
    weight of front wheel spindle > remove rear.
    IME most bikes are nose heavy even without the front wheel, if yours
    isn't you'll have to employ the services of a glamorous assistant.
    sweller, Jun 20, 2005
