So I have the ram 'universal mount' bit, RAM-B-309-1u It comes with bolts with threads that match the cat. The destructions say, remove brake clamp, fit RAM mount with new bolts, with a spacer inbetween the RAM and the existing bracket. If I use the spacers, they spread the bolts around the bar such that they don't do up, also the ram mount would not come close enough to the bar to clamp (the spacers are too large) If I clamp through the RAM mount and the original clamp it looks like it should work, but fails because the supplied bolts with the ram mount are too long. If I use RAM mount, spacers, original clamp, then it's fine, but the whole caboodle is loading through the plastic spacers, if one shatters then the brake lever is basically not attached to the bars anymore. Any thorts? Merci. Cat p.s. This is the ram mount which the RAM catalogue says is right for the thunderkitty.
