stumped...cant get my 2T started
Discussion in 'Motorbike Technical Discussion' started by beerismygas, Nov 29, 2004.
  1. beerismygas
    beerismygas Guest
    hi there, i am stumped. i cant get my engine to start.ive taken the
    carb (dellorto sha) apart,cleaned it and reassembled.i am puzzled
    because after the engine fires and stalls, plug is wet.these are the
    observations:
    -starts for 1 sec with starting fluid or splashing fuel into the air
    intake,
    when i check plug is wet with fuel around central insulator
    -visually confirmed spark
    -float and float needle appear to function well. with carb inverted
    and weight of float acting down on valve , i cannot blow air past
    valve.
    -float does not appear to contain fuel inside it.it is free to move on
    its pivot.
    -i can blow air and felt blown air output through the main jet to the
    venturi & through idle circuit
    -i suspected flooding of some sort but this happens even if i try
    starting with petcock at off position after i turn it on for a few
    seconds to fill float bowl.
    -tried starting with almost every combination of choke and throttle
    position.most commonly recommended here was choke with half throttle.
    -used 2 different sources of gas, tried even raw petrol
    -could it be an air leak at cylinder head?if so would the plugs be wet
    when it stalled if its sucking air and running lean?
    -the exhaust has some leaks.can this affect starting?
    -if i have a leak at the carb connection to crankcase, would this lead
    to plugs ending up wet?
    i have tried everything i could think of. any ideas what is left to
    check?
    many thanks
    B
  2. beerismygas
    LJ Guest
    What led up to this difficulty?
    Can you see fuel seeping out the carb?
    (Is the float leaking , mal-adjusted or saturated?)
    LJ, Nov 30, 2004
  3. beerismygas
    Carl McNamee Guest
    I'm going to concentrate on the carb since that seems to be the item you
    changed last and you indicated that the bike will run when using starter
    fluid. You mention that the float and needle are functioning, but is the
    float level correct? If float level is too high, the fuel mixture will be
    rich. If float level is too low, the mixture will be lean.
    More importantly for the problem you are describing, is the needle valve
    sealing completely shut when the float bowl is full? It might be worth the
    time to pull the carb off and test it on a bench to be certain that the
    needle valve is not leaking.
    Carl
    Carl McNamee, Nov 30, 2004
  4. beerismygas
    beerismygas Guest
    i loaned it.
    float appears intact. after many failed start attempts the metal air
    cleaner element will feel wet.
    thx
    beerismygas, Nov 30, 2004
  5. beerismygas
    beerismygas Guest
    thanks for all your replies. i think i might have additional probs
    with air leaking past carb.
    when the motor is turned with my finger instead of plug i can feel
    great compression and alternately considerable suction.if i put my
    finger on the carb 'spigot' (on the reed valve block where you attach
    carb) i feel almost no suction when motor is turned. it can just move
    a piece of tissue paper.
    how much suction should be at the spigot?
    also i pulled out reed valve. the thin metal was not fully closed. at
    atmosphereic pressure should the reed valve be *fully* shut or is it
    acceptable to have a little curl at the end?
    many thanks
  6. beerismygas
    John Johnson Guest
    Think about what is inside the 2-stroke cylinder. There is a piston going up
    and down as you turn the crankshaft...
    The exhaust port and the transfer ports are *closed* until the piston reaches
    the half-way point in the downstroke...
    So the piston creates a partial vacuum in the cylinder and you feel that
    vacuum
    *sucking* against your finger at the spark plug hole...
    Then the piston goes past the open ports and the sucking stops...
    No compression starts until the piston again closes the exhaust and transfer
    ports at the half-way point in the upstroke. Then the piston begins
    compressing
    the air in the cylinder and you feel it at the spark plug hole...
    Bottom line is, you have some compression...
    [/QUOTE]
    The key here is "some." From some experiments in my (comparable) youth,
    I found that I could only hold about 40psi with my thumb pressed against
    the end of a hole. People with stronger hands could certainly hold more
    pressure, but just because someone senses "great compression" doesn't
    mean that the engine has enough compression to operate effectively.
    Of course, I'm not there, and I'm too young to have 'enjoyed' the
    two-stroke years, so you might choose to disregard this anecdote.
    YP(ressure)M(easurement)MV
    John Johnson, Dec 1, 2004
  7. beerismygas
    John Johnson Guest
    found that I could only hold about 40psi with my thumb pressed against the
    end
    pressure, but just because someone senses "great compression" doesn't mean
    that
    [snip]
    The 2-stroke in question probably only has about 90~100 psi cranking
    compression. I could tell the owner to warm the engine up and hold the
    throttle
    wide open to take an accurate compression reading, but he can't get the
    friggin' engine started to warm it up...[/QUOTE]
    Yeah, and if he can hold 90psi with his finger in the spark-plug hole,
    then his compression is likely ok. If he can only hold around 40 or so,
    then it seems to me that his compression is rather low. As I said, I'm
    no expert on these things, but it does seem a bit surprising to me that
    you can hold in the full compression pressure of an engine with your
    finger.
