Street Triple conked out
Discussion in 'UK Motorcycles' started by The Older Gentleman, May 21, 2010.
  1. On my way back from a Morris session tonight. Only three or four miles
    from home. I'd been riding it slowly in high gears - six points on my
    licence, and 10pm on a Friday night is prime nicking time - and I
    noticed the instrument illumination getting dimmer. And then it died.
    I can only assume that with the twin headlights and the FI, it wasn't
    going fast enough to charge properlly. The Doctor came out with jump
    lads, it started, and I nailed it the last few miles home.
    I flattened the battery before by leaving the parking lights on, and
    I've been told those little gel batteries don't like it, so I guess it's
    new battery time.
  2. The Older Gentleman
    Nige Guest
    99 R1 going strong :)
    Nightmare tho matey, get a new battery anyhow, keep the old one just in
    case.
    Nige, May 21, 2010
  3. The Older Gentleman
    which, as was posted in another thread, is bollocks. AGM/gel batteries are
    used in deep discharge systems such as remote control vehicles &
    wheelchairs. You do need a particular type of charger to recover them from
    very low volts. An Optimate (unless a mk4) won't have enough oomph to
    recover a deep discharged gel or AGM battery. These are recognised as the
    best for the job: http://www.ctekchargers.co.uk/ which can be had for under
    £30
    wessie, May 21, 2010
  4. The Older Gentleman
    I'll be replacing my Optimate 3SP with one of these because it is much
    better at reviving dead batteries. My optimate refused to even give a
    very dead battery a chance, but a C-Tek has brought it back to life
    again and it's holding a charge nicely.
    Lozzo, May 22, 2010
  5. The Older Gentleman
    crn Guest
    Check your charging circuit, it should be able to cope with this.
    A dud battery is always possible but I would be more inclined to suspect
    a charging problem. There are normally 3 windings going to a diode
    block, if one diode is stuffed it would account for your problem.
    Also check for corroded or loose connectors.
    crn, May 22, 2010
  6. The Older Gentleman
    Check that there aren't any Italian parts on the bike.
    Andy Bonwick, May 22, 2010
  7. The Older Gentleman
    Simon Wilson Guest
    Actually, crn might[1] be right on this one. It's still in warranty
    right? I'd get the dealer to check it.
    [1] hedges bets
    Simon Wilson, May 22, 2010
  8. Yes, I did wonder. It's certainly charging, because when I got home,
    three-four miles, there was enough charge now in the battery to fire it
    up on the starter.
    I'm going to stick a multimeter on it now and take a few readings.
    The Older Gentleman, May 22, 2010
  9. Hm. I left it on the charger last night, and stuck the meter on it.
    13.4-13.5v, which is about right. Turned on the ignition and the reading
    fell to 12.4v, which as the headlights are always on and the FI engaged,
    again sounds about right.
    Fired it up and according to the multimeter it's charging at 17-18v,
    which strikes me as too bloody *high*.
    Time to give Rosner's a ring, I think.
  10. The Older Gentleman
    Derek Turner Guest
    And, alleluia, I select channel islands shipping (£7.49) and the vat
    drops to zero. If only all online shopping carts were like this...
    I'm choosing components for a computer upgrade on the basis of what
    Amazon themselves sell as nine times out of ten if I buy from one of
    their 'partners' they either won't deliver here or charge vat.
    Thanks for the heads-up.
    Derek Turner, May 22, 2010
  11. The Older Gentleman
    crn Guest
    All of your symptoms are consistent with a faulty reg/rec or corroded
    connections. The high voltage could have ALSO damaged the battery.
    crn, May 22, 2010
  12. Yeah, Rosner's says the charge rate is too high (as if I didn't know).
    Reg/rec looks the culprit, indeed. Booked in for warranty work. No
    corrosion anywhere, btw.
  13. The Older Gentleman
    Simon Wilson Guest
    A new battery as well as the rr I hope.
  14. Good point.
  15. The Older Gentleman
    Excuse me while I try to drag myself up off the floor after a vein
    bursting laughter fit.
  16. The Older Gentleman
    malc Guest
    I've just had to change the regulator on the ZZR. What fooled me at first
    was the normal charging voltage but of course I hadn't checked it with the
    lights on. With lights the voltage never got above 12.4 volts. Got one off
    ebay for only £20.
    Malc
    Rusted and ropy.
    Dog-eared old copy.
    Vintage and classic,
    or just plain Jurassic:
    all words to describe me.
    malc, May 22, 2010
  17. The Older Gentleman
    Higgins Guest
    You might need to be prepared for an argument on that, if they start
    trying to wriggle by pointing towards the warranty on the battery. 6
    months, IIRC.
    Higgins, May 22, 2010
  18. The Older Gentleman
    flashgorman Guest
    I think your bike has just become self aware. Were you riding with
    visible hankerchiefs?
    flashgorman, May 22, 2010
  19. The Older Gentleman
    Pete Fisher Guest
    Pah, pikey rosbif bike manufacturers. Voxan replaced the battery
    (actually branded 'Voxan') on the 'tart' nearly two years after I bought
    it. In fact, theoretically the battery could have been 6 years old by
    then because my bike was actually a 2000 model. TBF, it has needed
    another two batteries since then, so I think they rather admit that its
    location down by the oil tank and rear pipe isn't conducive to
    longevity. The Varta in it now is OK after 12 months, so fingers
    crossed.
    | Pete Fisher at Home: |
    Pete Fisher, May 22, 2010
  20. The Older Gentleman
    All you needed there was a <guffaw> and you could have been an
    Israe^HHHHH Sco^HHH Padd^HHHH sad bastard.
    Care to elucidate?
    Pip, May 22, 2010
