Hi all, Not a problem (I think), but I am curious. When I looked at my VF400F while the sun was about to set, I noticed a strange (but regular) series of shades on my front tire. The tire is a Dunlop Arrowmax K625A, mounted correct, and the wheel is balanced. There is no vibration on the handle bars too. The tire is about halfway it's life, about a year old (I don't take a note when I buy a tire), it is not dried out, and never repaired. I ride the bike on average 4 times a week, which is approx 400 miles each week. Note that the pattern on my tire differs from the arrowmax K625A shown at the dunlop web site, so I describe the pattern below. The pattern on the rubber looks as fat arrows, split over the full length from point thru shaft in a straight line, so it looks as if there are a series of split arrows on the tire. The arrow-points hit the tarmac first, which is the way it should be. Arrows are 3" long, the head is 2" wide, 1" long, and the shaft is 2" long and 1" wide. The strange wear pattern that I have is on the last part of the shaft, about an inch (25mm) long, and that shaft end is about 1/32'' (1 mm) lower than the next arrow point (which comes about 1/16" (2mm) after that lowered shaft end). So the shaft ends all wear faster than the rest of the arrows. This I can imagine because the shaft is smaller than the arrow heads. But....... a) The strange thing is that only the shaft ends of the left 'splitted' arrows are lower. The right hand is still at the same level as the rest of the arrow. b) The 'worn out' shaft end dives neatly (not abrupt) with a curve to that lower position. And all of the arrows have the same wear of that left shaft end. Now, I am a front breaker (rear doesn't do much) and the anchor plate of the brake holds on to the left front fork. So I thought that that could be the reason. Wrong tire pressure would affect both shafts, not only the left hand side (I suppose). Could be a worn out shock on the left side (I had that for a while), but I don't know. But maybe somebody out of cycles.tech-land has seen this before and can enlight me on the cause. Rob.
