Well, strange to me. This has been deliberately posted to UKRCM for any auto sparks to muse over.My bike was not charging its battery especially when running with the lights on. So I checked out the excellent flowchart here - [URL]http://www.electrosport.com/electrosport_fault_finding.html[/URL] My bike was failing on the first test basically when checking the voltage between the red RR lead and the positive terminal of the battery. [1] I was getting a reading of between 0.45 and 0.65 volts. So I duly ripped open the tape on the loom and tore out the red wire from my battery to the RR and ignition block connector. I got new connectors and the wire was slightly thicker than what I had removed. I also replaced the connector at the fuse with an in-line fuse holder. I connected everything up and checked the readings. A charging rate of 13.6 to 13.8v. Not that great but acceptable. Reading between RR red wire and battery positive - 0.4v. Bollocks. I continued to run the bike for about five to ten minutes as I basically farted around and wiggled and poked things and decided to check on the readings. The reading between the RR red wire and battery positive had gone into minus volts and the charging rate had disappeared up its own arse and was around 11.8v. The RR was also bloody hot after such a short time. Light was fading and I was pissed off, so I covered the bike. Tonight, fully refreshed, I checked all the wiring I had replaced in the loom. Everything looking OK. Start up bike. Charging rate of 14.2v to 14.5v. Result! I let the bike continue to idle for around five to ten minutes again and checked the charge rate. 12.7v and visibly falling as I held the meter on the battery. Shit! The RR was also rather hot. So, my question is. What's gone wrong? I have my own theory but I would like to hear suggestions as to what the hell has happened. [1] A week or two before this it had flattened the battery and it had failed on the next test but as this was simply cleaning up the earth connections it was quickly cured.
