Storing spares
Discussion in 'UK Motorcycles' started by Eddie, Aug 8, 2007.
  1. Eddie
    Eddie Guest
    My spare set of brake calipers seem to attract moisture and start
    furring incredibly quickly, even if an ant pisses in next-door's garden.
    Is there anything I could coat them in to stop this happening, without
    risking damage to the seals?
    What about wrapping them up, or storing them in something? Wrapped in an
    oil-soaked cloth? Airtight box with silica gel? Any other suggestions?
    Eddie, Aug 8, 2007
  2. Eddie
    SteveH Guest
    Greased brown paper - the stuff chains come wrapped in.
    SteveH, Aug 8, 2007
  3. Is there anything I could coat them in to stop this happening, without
    Snip
    That ACF50 is great stuff, failing that just take out the seals and
    spray the whole thing with WD40.
    Hope this helps.
    Miles Reading, Aug 8, 2007
  4. Eddie
    Resealable food freezer bag.
    Pip Luscher, Aug 8, 2007
  5. Eddie
    Beav Guest
    ACF 50
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 8, 2007
  6. Eddie
    zymurgy Guest
    Move somewhere less ... rainy ;)
    I like your oil soaked rag idea. As long as the oil is nowhere near
    the seals or any connected hoses, they'll be ok.
    You could copaslip around the pistons and the inside surfaces, you can
    get spray copaslip that goes on thin, then wipe out before use.
    P.
    zymurgy, Aug 8, 2007
  7. Both of those would work. I'd put them in a ziplok bag with the silica
    gel. If you want large amounts of silica gel for free, ask at a steel
    stockholder - they commonly take deliveries of steel with 1kg bags
    thrown in the consignment.
    GS850x2 XS650 SE6a
    river cleaned out in a day.
    Grimly Curmudgeon, Aug 9, 2007
  8. Eddie
    Eddie Guest
    A number of people have suggested this, but is it safe to use with the
    seals? And presumably I need to make sure it doesn't get inside the
    calipers.
    Eddie, Aug 9, 2007
  9. Eddie
    Yes, but keep it away from the polar bears. It stains their coats, see?
    CT, Aug 9, 2007
  10. Eddie
    Beav Guest
    It's safe for every electrical material I've ever used so I doubt that it'll
    cause a rubber seal will fall apart.
    As for getting it inside the caliper, I can't see how it could. They're
    sealed at both the inlet (and if not, bunging the hole up would soon sort
    that) and the seals of which you speak are stopping anything getting up the
    other end.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 9, 2007
  11. Eddie
    Eddie Guest
    It's only sealed at the inlet when it's connected to a brake hose, but
    I'll stick something in the 'ole to make sure it can't get inside.
    Actually, I've got some of that Scottoiler FS365 stuff; that should do
    the job, shouldn't it?
    Eddie, Aug 9, 2007
  12. I know a bloke what delivers steel, I'll have an ask of him when next I
    am lusting after his burd.
    steve auvache, Aug 9, 2007
  13. Eddie
    Beav Guest
    Yeah, it's along the same lines as ACF 50.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 9, 2007
  14. Eddie
    Donald Guest
    I was under the impression that the FS365 is a water soluble so not so
    good for long term storage.
    http://www.scottoiler.com/pc/Bicycl...Refill_(UK_MAINLAND_CARRIAGE_FREE_OFFER).html
    FS 365 Protector Spray is a blend of mineral oil, surfactant,
    anti-corrosion additives and water which forms a stable micro-solution
    that can only separated by evaporation.FS 365 is water soluble and
    therefore inherently biodegradable, it clings to all surfaces
    lubricating and preventing the onset of rust.
    Donald, Aug 10, 2007
  15. Eddie
    Eddie Guest
    < snip >
    The components in question are Tokico 6-pot brake calipers. They seem to
    need rebuilding (and hence swapping the spare set for the in-use set)
    every 6 months or so, so your values of "long" might need re-evaluating.
    Eddie, Aug 10, 2007
  16. Eddie
    Beav Guest
    Yeahbut water soluble doesn't mean that it wont protect against
    condensation. Water based paints are waterproof once they're dry (as an
    example)
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 10, 2007
