Stopping Engine Storage Moisture Ills
Discussion in 'Motorbike Technical Discussion' started by Jeff, Oct 29, 2003.
  1. Jeff
    Jeff Guest
    The most crucial areas in need of protection are the piston rings,
    cylinder walls, and valve seats. The enemy here is moisture, which can
    enter the engine from any of a number of places and cause serious
    damage. Since its not really practical to try and close up all of the
    possible areas of entry, we will concentrate on moisture proofing
    instead. The best way to do that is store your motorcycle in an
    airtight enclosed cover with six pounds of a desiccant. This way the
    moisture will not rust the piston rings to the cylinder wall, plus
    your complete bike will remain as dry as toast.
    If you find this information you have just read valuable, you may be
    interested in a report called "How to Effortlessly Protect Your
    Motorcycle Head to Toe During Storage". To get a copy of the free
    report go to http://www.motorcyclecaresecrets.com and click on the
    "Free Special Report" at the center of the page.
    Take Care,
    Jeff
    Jeff, Oct 29, 2003
