Stoppies
Discussion in 'Australian Motorcycles' started by Uncle Bully, Sep 24, 2003.
  1. Uncle Bully
    Uncle Bully Guest
    Been watching some stunt videos and was wondering how a stoppie works?
    They're easy enough on the pushy, but a pushy is light, and very top heavy,
    and when you do it, the bike stops. How do these guys get a 200kg motorcycle
    to lift the back wheel while still rolling forward? On one clip a guy rides
    the front wheel for over 500 ft.
    I would've though that just jamming on the front brake would slide the bike
    from under you (as I 've just about done a few times doing emergency stops),
    so how does it work?
  2. Pull the brake lever in gently to start then pull harder. Hard enough to
    lift the rear but not too hard/sharp to lock the front.
    Easy really.
    Aaron
    ZX6R
    Aaron & Kylie, Sep 24, 2003
  3. Uncle Bully
    Uncle Bully Guest
    fooking 'ell, got a video?
  4. Uncle Bully
    MadBiker Guest
    its simple. front brake goes on, front suspension is compressed with weight
    transfer, weight transfer keeps going and rear wheel becomes air borne, im
    guessing they ease off the brakes a little to keep rolling now. the rear
    wheel will be spinning, this keeps the bike inline with centrafugical force,
    if the rear wheel stops, then the bike will probably swing around it self as
    weight transfer does its best to make you go arse over end..
    Im also guessing its in the quality of your brakes, more bite gives you more
    force, im also guessing a heavier bike may be easier,a s more weight being
    transferred, but I could be wrong, im a two fiddy rider until xmas.
    cheers
    Nathan
    MadBiker, Sep 25, 2003
  5. Uncle Bully
    Smee Guest
    Ah well that rules out another thing shafties don't do.
    Bloody telelver front end does not compress enough to even attempt a stoppie.
    Smee, Sep 25, 2003
  6. Uncle Bully
    vinyl Guest
    I got the back wheel in the air on the R1100RT, smee. I didn't like it.
    Neither did Mrs CH who was the pillion, but the ABS did its job and saved
    the front from skidding. Skidmarks aplenty elsewhere though!
    vinyl, Sep 25, 2003
  7. (Note, this is advice from someone who doesn't do intentional
    stoppies, so read it with all that authority in mind :)
    Its all about getting the weight transfer right (well - mostly,
    anyway - some bikes just won't do it - long low bikes, cruiser
    style, are likely to _always lock the front before stoppieing).
    The reason you've seem people lock the front on emergency stops
    is usually because thay're doing it wrong[1]. If you grab a big
    handful of front brake on just about any bike, you will lock the
    front wheel. If you do it "properly", using the technique the NSW
    RTA ridier training calls "setup and squeeze", then you are
    _much_ less likely to lock the front, and on many bikes will lift
    the rear wheel off the ground. You need to brush the front brake
    lightly, let the front suspension compress, then gently squeeze
    more and more lever pressure on, further compressing the
    suspension, and also flattening out they tyres contact patch.
    Its actually not that hard - I can tell when I'm pushing my
    limits coming into turn 9 at eastern creek - I change down 2
    gears on the way in there, and usually the rear wriggles round a
    little each time I let the clutch out - sometimes tho, I'm on the
    brakes hard enough that it doesn't... Thats when I'm _extra_
    careful about making sure I'm off the brakes before tipping in
    for the turn...
    big
    [1] Yeah yeah Clem, just ask Zebee...
    Iain Chalmers, Sep 25, 2003
  8. Uncle Bully
    Smee Guest
    the rt?
    farknell that would have been some feat.
    dunno if the r1100s would be able to tho
    Smee, Sep 25, 2003
  9. Uncle Bully
    vinyl Guest
    Did I need to say that it was not done on purpose? :)
    vinyl, Sep 25, 2003
  10. Uncle Bully
    conehead Guest
    I don't think that fork compression or dive has too much to do with it.
    When you're two-up with rally gear on the bike the vast majority of the mass
    of the whole shebang is way above axle-height. Combine braking force with
    front-tyre traction and you'll get a rapid lightening of weight at the back,
    and a squishing of firm ample breasts into your back, and a compression of
    nutsack into tank, and an unrequested stoppie.
    Sounds easy. Scared the bejesus out of me.
    Wheelies? Nah, they take a bit of skill and planning.
    Conehead
    "Your credibilty along with all the other people arguing in this thread has
    been totally distroyed... I am copying this thread and will send it... but
    I'll send it not to the parents, but to a couple of magazines I know..."
    kiwipete in a hissy-fit
    conehead, Sep 25, 2003
  11. Uncle Bully
    conehead Guest
    Firm?...no. Ample?....unfortunately, yes.
  12. FFS no pics.
    Aaron
    ZX6R
    Aaron & Kylie, Sep 25, 2003
  13. Uncle Bully
    Nev.. Guest
    ....and just to prove me wrong someone went and broke that record the
    weekend before last so the new record stands at 266 metres (873 feet)
    Nev..
    '02 CBR1100XX #2
    Nev.., Sep 25, 2003
  14. Uncle Bully
    John Littler Guest
    It's a bit like popping monos on under powered bikes Clem - throw your weight in
    the desired direction to help it lift and then balance..
    The TRX didn't have any better forks than the XJ I don't think. It's more about
    brakes, and tyres anyway. I'd only do them intentionally at lower speeds -
    Aaron's 100K is more than I'd do - try 'em at 20-30K. Sticky tyres and good
    brakes make it easier. When the forks start compressing throw your weight
    forward (and try not to lock up the front :)
    JL
    (stoppies are easier than monos...)
    John Littler, Sep 26, 2003
  15. Uncle Bully
    Aaron@work Guest
    Stoppies are easier but once you get to the point of no return with a
    stoppie you're fucked. At least with a wheelie you can mash (assuming you
    don't miss it) the rear brake and hopefully that'll do something for you.
    Aaron
    ZX6R
    Aaron@work, Sep 26, 2003
  16. Uncle Bully
    Dale Porter Guest
    It was entertaining watching the Police bikes getting air between their rear tyres and terra firma
    at the Sandown cornering and braking sessions a coupla years ago.
    Dale Porter
    Dale Porter, Sep 26, 2003
  17. Uncle Bully
    I'm slowing for the lights at Aspley and I thought I'd give it a go so I pull on the brakes until the forks
    are right down and then I lean forward and squeeze a bit harder and CRACK!!
    I think I might put off further attempts until I've replaced the 150,000km-old steering-head bearings.....
    Clem
    ( I bet the person behind me thought "crack" too, as he watched my arse rise up into view!)
    Knobdoodle, Sep 30, 2003
  18. Uncle Bully
    conehead Guest
    He probably thought, "That reminds me, I must post the Christmas presents
    earlier this year".
    conehead, Sep 30, 2003
  19. Uncle Bully
    John Littler Guest
    Uhoh, forgot the warning, stoppies at traffic lights are high risk,
    when cars regularly stop at a place what do you often find ? Oil .
    This can be nasty when you're on the front wheel and you suddenly lose
    traction...
    JL
    John Littler, Sep 30, 2003
Similar Threads
Loading...
