Stopped stoppieing
Discussion in 'UK Motorcycles' started by spida, May 29, 2004.
  1. spida
    spida Guest
    gixxer yum[1], brakes noo, fixum how?
    a) Change BF - 1 year old.
    b) Unfuck pistons - not sure if they are fucked - how do you tell? [2]
    c) Add braided hoses - seems to be most popular mod - does it make a
    real difference?
    d) Change pads.
    e) Add wavey disks.
    f) Something else.
    All abuse gratefully received.
    [1] K1 15K
    [2] Mechanical competence level extends to adjusting chain tension and
    replacing blown bulbs.
    spida, May 29, 2004
  2. spida
    Ginge Guest
    Write in fucking English, you inarticulate cabbage.
    Ginge, May 29, 2004
  3. spida
    Robbo Guest
    a) Do it
    b) Do it
    c) Yes
    d) Yes
    e) Not worth it
    f) take evening classes in English
    if all else fails to improve the situation get a pushbike.
    Robbo
    BMW K100 RS 1984
    BotaFOF #19. E.O.S.M 2001/2002/2003.
    B.O.S.M 2003.FURSWB#1 KotL..YTC449
    PM#7
    Robbo, May 29, 2004
  4. spida
    Try describing the symptoms and their severity - in English - and
    perhaps somebody might know the answer.
    Pip, May 29, 2004
  5. spida
    Ben Guest
    Tokico brakes. They shit. Live with it.
    Seriously, EBC HH make a nice difference, as do braided hoses. Other
    than that just make sure they clean, all the seals are ok etc.
    Ben, May 29, 2004
  6. spida
    spida Guest
    I always knew they're weren't the best after a test ride on the 636,
    but things have got downright dangerous now.
    Cheers.
    spida, May 29, 2004
  7. spida
    spida Guest
    Symptoms:
    a) Increasingly greater effort required at lever to get any kind of
    breaking effect.
    b) Lever travel does not seem to have increased significantly.
    c) A couple of sharp applications of brake initially used to improve
    braking performance but now has very little effect.
    d) I don't think the disks are worn, there's no sign of a ridge if you
    run a thumb nail across the surface.
    spida, May 29, 2004
  8. spida
    spida Guest
    Well no it didn't, but I appreciate the effort.
    spida, May 29, 2004
  9. spida
    spida Guest
    You must be joking - I used to enjoy riding a pushbike on the road,
    now it feels suicidal.
    spida, May 29, 2004
  10. spida
    Pads are glazed, I reckon.
    New pads required, braided hoses may help too.
    Carbon Lorraine SBK3 from Hein Gericke at ~54 quid for both pairs.
    Pip, May 29, 2004
  11. spida
    CampinGazz Guest
    Are the pads fucked?? either worn out so your braking on the metal.. tho you
    should hear it if it's that bad,
    or the pads could be glazed to hell, or the linings gone hard... the sharp
    aplications of the brakes to get things working make me think that,
    Cheapest things to do.. whip the pads out and have a look see i'd have
    thought, might be able to do a temporary fix with some emery paper if they
    are glazed to hell, but it wont last long,
    remember i last worked on a bike 10 years ago mind, so don't believe all i
    say.
    CampinGazz, May 29, 2004
  12. spida
    spida Guest
    Ta, pads and hoses it is then.
    spida, May 30, 2004
  13. spida
    spida Guest
    Sounds like the problem is glazed pads. If you don't hear from me
    again it was something else.
    spida, May 30, 2004
  14. spida
    Ben Guest
    I'd suggest EBC HH over the Carbone Lorraine ones. I used both on my
    GSXR750 and the EBC were noticeably better.
    Ben, May 30, 2004
  15. spida
    Ben Guest
    Oh, was he talking about the 4 pots? I had the 6 pots on my 750 as
    well as being on the Thou. Oddly the 4's are supposed to be better.
    Ben, May 30, 2004
  16. spida
    deadmail Guest
    They (the Tokico 6-Pots) were competent enough on team-ukrm's race bike
    last season.
    I think definitions of 'shit' vary somewhat.
    deadmail, May 30, 2004
  17. spida
    deadmail Guest
    I've read (somewhere) that the EBC HH give the disks a hard time and can
    result in warped disks/worn out disks. Don't know if there's any truth
    in this.
    I've used the HH pads and was impressed but I don't think I'm that
    demanding a rider.
  18. spida
    spida Guest
    It was the 4 piston jobbies on my K1 600 that I was on about. I never
    felt entirely confident with them from new, but you could squeeze a
    stoppie out of them so I suppose they were good enough. But now, even
    a tendon snapping handful doesn't get close to lifting the back wheel.
    spida, May 30, 2004
  19. spida
    Ben Guest
    Never had any problems and I've used them on all bikes since the SV in
    2000. They're not in the Thou yet, but that's because it's still on
    it's original pads.
    Likewise and likewise.
    Ben, May 31, 2004
  20. spida
    Ben Guest
    Hmm, might look to change. The OP did say he had a K series, a K1
    IIRC. I just assumed that they had 6 pots like my WW.
    They do look the bits you've got to admit. But the 98 WW had the same
    6 pots in black.
    Ben, May 31, 2004
