Steering lock removal. 251 MZ
Discussion in 'UK Motorcycles' started by Merlin, Feb 2, 2005.
  1. Merlin
    Merlin Guest
    I need to replace the steering lock ignition switch unit on my ETZ251
    as the switch is buggered.
    It is held under the top yoke with what appear to be hardened M8
    security bolts with those tapered lugs which will only allow it to be
    tightened one way. The only way of getting em out seems to be to
    remove top yoke (a pain) and grind the heads off with an angle grinder
    and then turn the stems out. I tried drifting em round with knock
    stick and sharp chisel but it just bounces off. There is also little
    room to move.
    I really dont want to take yoke off, but if that's it, then that's it.
    Thanks
    JSM
    Merlin, Feb 2, 2005
