Steering Head Bearings (again)
Discussion in 'UK Motorcycles' started by Christofire, Jun 16, 2004.
  1. Christofire
    Christofire Guest
    After Bonwick's help in tightening the steering head bearings they were
    all lovely and great. Some miles later they're back to the loose,
    knock-knocking again, so it looks like they need replacing. As I see
    it, there's two options:
    1) get all the tools, some bearings and beer (for enlisting help) and
    try myself or
    2) throw the bike and money at a dealer.
    As I suspect 2) will involve a fair chunk of money (and I don't get on
    with the nearest dealer) I'd like to do 1. One way or another I can
    get the tools, so that's ok, but how do you go about getting the
    bearingsfrom your local bearing manufacturer?
    Secondly, if they're knocking, what damage will I do to the bike if I
    carry on riding it[2]? None, some or lots?
    Finally, are there any of those well-written technical articles
    explaining what they do so I can understand what I'm wibble-flipping
    about?
    TIA for the hand-holding.
    [2] Presuming I don't bin it.
  2. In uk.rec.motorcycles, Christofire burped loudly and ejected the
    following:
    Firstly let me say my mechanical expertise stretches to oil changes,
    lubing cables and stuff and way, way back I fitted a big bore kit and
    assorted bolt-on go faster goodies to a TS50X.
    I would go for the first option. Buy the tools because you'll always
    have them and get SWK to supervise, that way you'll be good to go in the
    future.
    I had knocking steering bearings on my last bandit for 20,000 miles and
    it was ok, I only noticed it when braking when there was a notchy feel
    as the forks compressed.
    http://science.howstuffworks.com/bearing.htm
    Whinging Courier, Jun 16, 2004
  3. Christofire
    WavyDavy Guest
    Hmmmmm.. So *your* head bearings were knackerd and mine were fine. Then
    *you* take my Daytona out and now *mine* are rocking like a pony with Gene
    Autry on it....
    I seem to detect a connection...
    So I'll send the bill to you, yeah?
    Maybe not.
    But in the same vein, do modern bikes still use just normal ball bearings in
    the heads?
    Is it worth doing the standard 80s style nod and getting a taaper roller set
    in instead, if they are still BBs?
    If so, what do I order and how much more will it cost me?
    TIA
    WavyDavy, Jun 16, 2004
  4. IIRC between £200 & £300 quid.
    getting the bearings are a doddle, just phone your dealer and ask for
    them (there are two of them, one that goes underneath the top bit
    (yolk?) and one that sits at the bottom of the stem)
    its fairly self explanatory but *YOU WILL* have problems getting the
    bottom set of bearings off. I know two people who have replaced them
    and both have had to grind them off the stem as the several sets of
    bearing pullers have either not had long enough legs to reach from the
    top of the stem or had too thick legs so they dont get under the
    bearings to pull them. <note from^h^h^to Tim> dont grind too much off
    the bearing, just enough to make it crack.
    I'm happy to lend you the too for removing the top bolt and the 36mm
    socket again.
    someone who knows will be along shortly to say I'm talking bollocks.
    Adie
    Triumph 955iSS / GSF600 bandit
    MRO#11 BOTAFOF#7 BOTAFOT#130 DIAABTCOD#17 MIB#24 YTC#16 BOB#15 ex-UKRMMA#22
    Adrienne M Jenn, Jun 16, 2004
  5. they are taper.
    IIRC something like £20 each.
    Adie
  6. Thieving bastards
    Find the sizes and order from BSL. You'll get the same things for less
    than 1/2 the money.
    Dremel grind a small notch into the ring. Use a hammer and sharp cold
    chisel to split the ring. Easy.
    I charge £120 for changing head bearings on a Pan Euro.
    + parts.
    ColonelTupperware
    spouting bollocks on Usenet since 1997
    Usenet FAQ at
    http://www.its.caltech.edu/its/services/internetapps/news/news2.shtml
    UPCE FAQ at http://upce.org.uk/
    UKRM FAQ at http://www.ukrm.net/faq/
    Colonel Tupperware, Jun 16, 2004
  7. Christofire
    Mark Olson Guest
    No, actually, you aren't... a Dremel with a mini cutoff wheel is exactly
    what is needed to deal with steering head bearings. As you say, just be
    damned careful not to grind too far. Put a good sized nick in the bearing
    and whack it with a chisel, it *will* break where you've ground it.
    Sometimes it can also be a bit of a bugger to get the outer races out of
    the steering head, when tapping them out with a drift, make sure you don't
    get them cocked at an angle, or you'll have to resort to Mr. Dremel there
    too.
    Mark Olson, Jun 16, 2004
  8. Christofire
    Christofire Guest
    They're having one.
    Righto - I'll see if I can find the manchester triumph dealer. I
    detest the one in Orrel as he's having a laugh with the prices. I
    wouldn't be surprised to hear that they're charging for just talking to
    them next.
    <snip horror>
    This is why I was considering the dealer option, but at 300 notes I
    think I'll give that a miss.
    Thanks muchly. I'll be down south the first weekend in July so will
    probably be able to pick it up then.
    Christofire, Jun 17, 2004
  9. I'm going into Flitwick tonight [1], do you want me to see if they
    have some bearings or can get some for you?
    [1] funnily enough to have my steering head bearings looked at. expect
    a rant about OYT later.
    Adie
    Adrienne M Jenn, Jun 17, 2004
  10. Christofire
    Tim Guest
    Unless you slip with an angle grinder :)
    Tim two#21, YGL#3 & BOTAFOT#84
    Due to the limitations of current email, the lip movements may be
    out of synchronisation as you move your finger under the text while reading.
    tim dot ukrm2 at dsl dot pipex dot com
    Tim, Jun 17, 2004
  11. Christofire
    Salad Dodger Guest
    I must say, these Triumphs sound jolly good. Where can I get one?
    I've got some cheese in the fridge, so I'm already well sorted for
    | ___ Salad Dodger
    |_\_____/_| ..66073../..15556.../..3157./.19406
    \|^|/ ANORAK#17
    '^' RBR-Visited:35 Pts: 705 Miles:2429
    Salad Dodger, Jun 17, 2004
  12. Christofire
    WavyDavy Guest
    Well I know yr taking the piss, but I have to say that my bike is 4 years
    old and, although it only had 10k on the clock when I got it, it may have
    been 10-ham-fisted-k-miles-before-I-had-it, as could Christofires...
    I've never had such a bad wobbly head bearing feeling ever like I started
    getting last week, not even on the CRM. Which is worrying, but the bearing
    quality is more than made up for by the engine character. And the pipe rack
    & slippers[1]
    [1] Although they were optional, unlike the as-standard Beemer and Goldwing
    equivalents...
    WavyDavy, Jun 17, 2004
  13. Christofire
    Salad Dodger Guest
    Not TEN thousand miles? Goodness gracious, that's lots of miles for a
    modern motorcycle to have to cover without dismantling.
    I wish I'd bought a Triumph, then I could have changed the bearings,
    erm, a dozen or so times, compared to the not at all that I've been
    subjected to on the CBR1000, Blackbird and Wing.
    | ___ Salad Dodger
    \|^|/ ANORAK#17
  14. Christofire
    Oooh, don't forget front wheel bearings (although mine lasted all of
    9000 miles, IIRC) and that there chain adjustment C-spanner...
    Ace, Jun 17, 2004
  15. Christofire
    Are you sure they don't just need adjusting? These clever modern taper
    bearings can take up the play.
    sweller, Jun 18, 2004
  16. Christofire
    Is this where I mention clutch master cylinders?
    Champ, Jun 18, 2004
  17. Christofire
    On my quasi-regular walk from Liverpool Street station to my place of
    "work", I pass a bike bay which has a Silver Daytona 600 parked in it.
    What a fucking *dreadful* looking bike. Looks like some 1995-era
    art-school wanker's idea of "futuristic". Simply horrible.
    darsy, Jun 18, 2004
  18. Christofire
    WavyDavy Guest
    It's getting a bit more use now... Its now on 14k and I'll be adding
    another 2 or 3 thousand in July. So I'll expect new bearings all round and
    a load of other things to drop off by August.
    Which ain't so bad when you consider I normally use a car for work and I do
    have the use of the wife's R6[1] too....
    [1] Which has had absolutely nothing go wrong with it at all. Yet.
    WavyDavy, Jun 18, 2004
  19. Christofire
    Nick Knowles says...
    It could be worse, it could be one of those ultra reliable BMW bikes.
    Lozzo, Jun 18, 2004
  20. well yes - there is one parked close to our office at St James Park. I
    keep looking at it and concluding along the lines of your above
    statement. Most odd looking thing.
    Paul Corfield, Jun 18, 2004
