Steering Damper Failure?
Discussion in 'Australian Motorcycles' started by Rob White, May 22, 2005.
  1. Rob White
    Rob White Guest
    Hey All,
    Was on the bike today, out for a ride, tipped the bike into a corner and
    felt something 'let go' steering went real loose... Sooooo much easier to
    turn the bars now...... Its a GSXR750 92' fitted with a Steering Damper...
    When i got home i removed the Damper.... how much of a difference do these
    things make exactly? as ive never ridden the bike without it... now the bike
    seems to want to just fall into the corner.... (even with it on)... i can
    move the rod in and out of the housing without any trouble but there is
    still a resistance there... no sign of oil or broken seals on the rod at
    all....
    Suggestions?
    -Whitey.
  2. Rob White
    GB Guest
    If you take your hands off the bars when you're riding in
    a straight line, does it want to wobble it's head? If so,
    does that bother you?
    GB
    GB, May 22, 2005
  3. Rob White
    Rob White Guest
    Yup, it does... and no it dosent bother me.... I ended up taking the stupid
    thing off... much easier to ride now.. did 600kms today so im thinking
    theres no problem with the bike..
    Rob White, May 23, 2005
  4. Rob White
    corks Guest
    just be careful later on when you
    are fanging it and hit a bumpy/shit road
    i presume suzuki put it there for a reason
    dc
    corks, May 23, 2005
  5. Rob White
    Rob White Guest
    noted.... well, thats the next question.. did they come standard?
    dosent say anything about it in the workshop manual.
  6. Rob White
    corks Guest
    im pretty sure most if not all of the gsxr1100 and 750's came with steering
    dampners
    also if you have the bike insured and you take dampner off, you may give the
    insurance reasons to say "see ya"
    lot of people leave them on and turn them down to the lowest setting, those
    thatn vcan be adjusted , unlike the poxy ones o fthe tls - but you could get
    them rebuilt with lighter oil in them
    corks, May 23, 2005
  7. Rob White
    Moike Guest
    I know >||< that much about Japanese sports bikes, but ISTR that the
    GSXR750 came without a steering damper, but one was fitted PDQ to cure
    an occasional rather startling head shake.
    OTOH I could be talking through mu arse.
    Moike
    Moike, May 23, 2005
  8. Rob White
    Nev.. Guest
    hmmm.. not too sure about that. I think lots of Gixxer owners fitted them,
    but don't think they were a factory item. I know my 93 GSXR1100 neither had
    or needed one, but then it was a bit porkier than the earlier 1100s.
    Nev..
    '03 ZX12R
    Nev.., May 24, 2005
  9. Rob White
    Rob White Guest
    Yeah, most definatley. Ive already had that happen to me, and that was with
    it on. I just couldnt see it 'going on me' without some sort of oil or a
    broken seal or some sort of tell tale sign.... [strange]
    Rob White, May 24, 2005
  10. Rob White
    FruitLoop Guest
    My 90 GSXR750 L had a damper fitted standard , I removed it and fitted a
    White Power I had at the time.
    FruitLoop, May 24, 2005
  11. Rob White
    GSXRBadBoy Guest
    .... how much of a difference do these things make exactly?
    I had a GSXR1100K... 1990 model. It came with a damper and when it leaked a
    bit of oil and wasn't working properly I ditched it. The bike was heaps
    better without it. I fitted an Ohlins rear shock and spring which lifted the
    rear about an inch. Even then the front end never gave any particularly
    troublesome shakes.
    Cheers Frank.
    GSXRBadBoy, May 24, 2005
